vf34 or 16g... same package price!
Old Mar 14, 2006 | 11:45 AM
projectwrx's Avatar
Car Info: wrx
vf34s (through gruppe-s) and 16gs (though importimage) are both going for $1299. what turbo package would you rather go for?
Old Mar 14, 2006 | 11:46 AM
kspek's Avatar
Car Info: non subarus
depends what you want to do with your car.
Old Mar 14, 2006 | 12:55 PM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
go with vf34 unless you plan on running better than 91 octane
Old Apr 4, 2006 | 02:01 AM
Stimo's Avatar
Car Info: STI
I don't think this is good info. Both turbos are close to the same, except the 16G will pull harder uptop. Lag will be minimal between the two. If i where you i would go for the 16G, as it is upgradeable, unlike the VF series turbos which you can do very little to.
Old Apr 4, 2006 | 08:44 AM
CKsubyCK's Avatar
Car Info: 03' Suby wrx
turb
If i were u id look at the big 16g, its a lil more money but the top end power that ull get out of it will be a huge difference. But if you are going between just these two id say the 16g, it spools nearly the same just more power uptop, and if u wanted to track it and ran like 103 octane ud see huge gains, but the vf34 is a great daily driver, but if u ever want more power your going to have to take it out and get a bigger one.
Old Apr 16, 2006 | 09:24 AM
USAF_STi's Avatar
Car Info: 05' STi
Get the 16g. it s capable of more power and still spools really well.
Old Apr 16, 2006 | 10:37 AM
You will not be able to run high boost with a 16g on 91 without risking det. That is where mitsu turbos shine is in the 20+ psi range but both are good turbos and that is why I made that statment. If you plan on WI or alky or mixing your gas then by all means go with the 16g but you will not see that much more from a 16g pushing the same psi or at least I have yet to see it in person. Remember numbers are numbers.
Old Apr 16, 2006 | 05:18 PM
USAF_STi's Avatar
Car Info: 05' STi
Still the 16g moves more air than the 34. 16 psi out of the 16g will make more power than 16 psi out of the 34. Also with a good tune 19-20 psi is safe on 91 oct.
Old Apr 17, 2006 | 09:45 AM
were talking 5-10hp difference at the same psi and like I said before I have yet to see the difference in person just on paper.
Old Apr 17, 2006 | 03:31 PM
subie OCD's Avatar
Car Info: 04 STi
Ditto
The vf34 is more proven. Both should make similiar results on 91 octane.
ravenlunatic
Jun 5, 2014 07:36 PM
Vladi
43
Oct 15, 2007 10:51 AM
WRX-CBR
Wanted
Jan 15, 2007 10:56 PM
robsrex
Mar 2, 2006 07:28 PM
biznessdude
Wanted
Nov 30, 2005 08:58 PM
