Possible BOV probme... tuning?
Old Dec 16, 2005 | 03:58 PM
labgeek's Avatar
I have a Sard R2d2 but I think its not working properly. I'm running stock boost but you only hear the BOV at around 3k Rpm. I thought the BOV should be louder when I gun it.
Could this mean that i'm leaking boost? Is there a way to tighten the BOV spring?
Old Dec 19, 2005 | 09:56 PM
AzN121184's Avatar
Car Info: civic
if your idling is rough, then your bov is probably leaking, however i doubt that's the case with the sard r2d2.
Old Dec 28, 2005 | 12:16 AM
KronikInsomniaK's Avatar
Car Info: 05 WRX WRB
you will only hear the bov when you build boost so your car probably isn't building up enough boost before 3k rpm to make the pssssh sound
Old Dec 28, 2005 | 04:43 PM
Boost Addict's Avatar
is the r2d2 a 50/50 BOV? that would answer your question if it is... Meaning prior to 3000 rpm it still plumbs back to the intake, while after 3000 youre actually creating excess boost to allow the valve to open far enough to vent to atmosphere.... If its a 50/50 bov, thats more likely than not, your "problem"
Old Apr 15, 2006 | 01:30 PM
se0ul's Avatar
Car Info: 04 wrx, 05 Elise, 14 Impreza, 17 brz coming soon
sard r2d2 usually only sounds off at 0 psi or when shifting at full throttle at very high rpms ..well at least for me and my setup.
Old Apr 16, 2006 | 01:15 PM
[W5]IntoTheWRX's Avatar
Car Info: wrx
for mine, just about any boost=the sard r2d2 will sound. when im at 3k+ its at full sound. mine will start sounding at 2k+ (the quieter blow off)
Old Apr 16, 2006 | 10:32 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
same here..mine blows off pretty early. its the prolly the loudest between 3-4k
Old Apr 17, 2006 | 05:52 PM
luvinboost's Avatar
Car Info: 02 wrb wrx
mine is the same it will sound off all the time love it. its loud *** hell. but last time i was going into a turn and kinda let off and i heard it kidna leak out and the exhaust started sounding kinda funny it got louder and more poppy i dont know it was weird.
EQ Tuning
Nov 2, 2017 05:05 PM
simontempler
Hawaii Classifieds
Nov 4, 2008 09:07 PM
Christian.
Apr 17, 2007 02:34 PM
EQ Tuning
Feb 28, 2007 11:20 PM
WorldONE
Jul 9, 2006 03:40 AM
