VF-39 in WRX???
Old Aug 16, 2004 | 01:29 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
VF-39 in WRX???
has anyone done this and what is your setup?
also can i run this turbo on stock injectors with a higher flowing fuel pump with tuning...
Rocky
Old Aug 16, 2004 | 01:42 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I would recommend injecors and the pump.
Old Aug 16, 2004 | 02:17 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
If you can get a VF-39 cheap....go for it!
Old Aug 16, 2004 | 10:36 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
What are the stats on the VF-39 ?
I can sell 3 of them since I already have a VF-34 awaiting install but I wanted to know how well do those perform compared to eachother ?
WRX Rush
Old Aug 17, 2004 | 07:39 PM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
P17 exhaust housing, compared to a 34's P18. It throws up comparable numbers though.
Old Aug 19, 2004 | 12:07 PM
wssboard18's Avatar
You need inj. and fuel pump to get anyhting out of this turbo, otherwise you will just have to run really low boost and it is not worth getting the turbo. It is simlar to the vf34, but not as much top end. You also need to get EM, somehting other than just a boost controler.
Old Aug 21, 2004 | 06:21 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
you know who i am going to be tuned by
Old Aug 25, 2004 | 05:19 AM
1badrex's Avatar
Car Info: '02 WRX
Rocky
Been there, done that! I'm currently running the vf39 in my '02 rex. I also upgraded the fuel pump with a Walbro 255L and the injectors with the jdm STI injectors. My UTECH was tuned by I-Speed. The turbo pulls hard and holds boost all the way to redline in 3rd and 4th with no knock. So far, I'm happy with this set up.
