USDM STI shortblock?'s
Old Jul 14, 2004 | 10:04 PM
AK'S REX's Avatar
What will be the approximate compression of a USDM STI shortblock(EJ257) w/ US stock WRX heads w/ OEM thickness gaskets?
What else is needed if anything in order to perform this shortblock swap, as far as oil pan, water pump, etc?
Is this block physically larger or smaller than the 2ltr? Just curious as to whether my intercooler, wastegate, etc. piping will fit the same.
Sorry about all the ?'s, I just haven't looked much into this swap. Recent developements w/ current shortblock build have led me to this being the best possible option while I finish my other shortblock on the side.
Thanks much in advance,
-AK
Old Jul 15, 2004 | 01:44 PM
ds baruuuuu's Avatar
Car Info: 5.4RS
about compression no idea might want to check out i-speed
the block is the same dimensions everything fits just you factory turbo will be too small for the 2.5 good luck
alwu
Mar 30, 2010 04:50 PM
kjh_glass
Mar 1, 2009 02:00 AM
geoff
Jan 24, 2006 12:34 PM
my sti 1
Oct 17, 2005 01:58 PM
turbonick
Apr 3, 2005 11:40 PM
