Up pipe swap
Old Jun 27, 2006 | 06:18 AM
ILiveAgain's Avatar
Car Info: 03 WRX Wagon
Up pipe swap
Hey Guys,
On Friday/ Saturday I plan to install my gutted up pipe. I've never done this before, and i plan to use the write-up on ScoobyMods.com.
Does anyone have any advice for me?
Old Jun 27, 2006 | 03:48 PM
meilers's Avatar
How long has the original pipe been on the car? If it has been more than 2 years, use lots and lots of Liquid Wrench on the bolts and let it soak in for 1/2 hour or more. After 2 years of being heated to 1600 degrees and then cooled, they tend to be a little stubborn
Old Jun 27, 2006 | 07:32 PM
Peaty's Avatar
I know I post a link in the how to but again this is a watch out:
http://www.scoobymods.com/forums/showthread.php?p=17902
Major PITA to fix if you do what I did.
BP Blaster is your friend. If you can soak them overnight do it. Also come back a few days later and re torque the bolts.
Old Jun 28, 2006 | 10:41 AM
ILiveAgain's Avatar
I'm probably going to start this tomorrow night (because the weather has cleared up here in MD). I'll spray the bolts, and let them sit over night.
I have already done the mechanical CEL fix for my O2 sensor thats on the mid pipe. Are what other "fixs" do i have to do for the up pipe?
Old Jun 28, 2006 | 04:12 PM
Peaty's Avatar
Check out my install you will see the proper resistor to install in the EGT harness.
Old Jun 29, 2006 | 10:09 AM
unstble's Avatar
Car Info: WREX
Well, it looks like you will also be learning how to do a downpipe removal & replace this Friday/ Saturday also....
I prefer to use PB Blaster on all the bolts I will be trying to get off - usually spray the stuff on about 15-20 minutes before going at it!
Oh, also make sure you have the parts (2.2k resistor) to do the CEL fix (prevent CEL from coming up)
Old Jun 29, 2006 | 06:41 PM
ILiveAgain's Avatar
Currently, i have the heatshield off and the O2 sensor removed.
do i have to do anything to the front O2 sensor to prevent a CEL?
Tomorrow i am going to install the 2.2k resistor, and hopefully get the DP and UP off.
Old Jun 30, 2006 | 05:25 AM
ILiveAgain's Avatar
bump for more info.
Thanks guys
Old Jun 30, 2006 | 07:55 AM
unstble's Avatar
Car Info: WREX
The sensor in the exhaust manifold needs to stay there...
You should also have new gaskets to use when putting on the new part(s).
I believe you will need a few different length ratchet extensions for the up-pipe to turbo bolts, and an assortment of box-end wrenches.
All the stuff the above posts, patience, and determination and you should be set to
Old Jun 30, 2006 | 08:27 AM
ILiveAgain's Avatar
New Gaskets : check
Craftsman Ratchet set : check
Determination : check
as long as time equals patience. I have plenty of time. haha
Old Jun 30, 2006 | 08:52 AM
unstble's Avatar
Car Info: WREX
Do you have deep sockets also? These may come in handy for clearance reasons...
This will be a "fun" project for the first time!
I also kept a floor jack nearby; for jacking up the engine a little (1-2 inches) to get the up-pipe out from the engine area.
Old Jul 1, 2006 | 11:28 AM
phisch's Avatar
Car Info: '04 Subaru Impreza WRX (Java Black)
I just did the gutted uppipe/ Helix catted DP install last night on my '04 wrx, took me 5 hours including a trip to Advanced Auto for the O2 socket. Stage 2 AP flash as well. Stock to Stage 2 is an awesome jump! It is so easy to get the uppipe out of you just take off the exhaust manifold. No engine lifting or any of that stuff. Had a lot of fun doing this install, first time doing this, could probablydo it again in much less time. Have fun!
Old Jul 1, 2006 | 12:17 PM
unstble's Avatar
Car Info: WREX
The next time you should be able to do it in about half the time.
I have remove and re-installed the up-pipe, downpipe, exhaust manifold, and cat-back about four times already - mainly because of leaks, and changing out parts for different parts - to see if there is any performance change from brand-to-brand parts.
Old Jul 1, 2006 | 12:31 PM
ILiveAgain's Avatar
Just finished the install. took me a total of 10 commited hours over 3 days. how many days should i wait to re tork the bolts?
Old Jul 1, 2006 | 01:22 PM
unstble's Avatar
Car Info: WREX
I believe you only need to get the car to operating temperature - take the car for a run (10-15 minutes) then park car, let cool down a little, then retorque.
