Up-pipe and Downpipe ?
Old Mar 2, 2004 | 08:29 AM
esracer's Avatar
Car Info: 2002 Honda S2000
Question Up-pipe and Downpipe ?
I'm getting my exhaust in a few days now and I have a downpipe I'm going to install with it. Do I need to buy a gasket to go between the downpipe and the Turbo?
Next Question:
If I get an up-pipe will that throw a cel? Do I need to buy another fix for the EGT sensor? and what gaskets will I need.
Thanks,
Raymond
Old Mar 2, 2004 | 08:56 AM
You should always replace exhaust gaskets when you break their seal.
You will get a CEL from the uppipe unless it has a bung for the EGT probe or you have a resistor for the CEL fix.
Old Mar 2, 2004 | 11:16 AM
esracer's Avatar
So basically what you're saying is that the HKS uppipe shouldn't throw a cel because it has a bung. But one question went unanswered. I understand that you should replace the gaskets, but are there a gasket between the turbo and the downpipe, and also is there a gasket between the turbo and the uppipe. Thanks for the info so far BAN SUVS, if you could answer or somebody answer my this last question, that would be great.
Thanks,
Raymond
Old Mar 2, 2004 | 11:20 AM
Aftermarket uppipes with an EGT bung *may* still throw a CEL, but that's somewhat uncommon. As for the uppipe gasket, yes, there is one there. Everywhere on the exhaust that has flanges bolted together, there is a gasket.
Old Mar 2, 2004 | 11:25 AM
esracer's Avatar
Thanks for the info bro
Old Mar 2, 2004 | 11:39 AM
WuWrx's Avatar
i got a CEL with HKS uppipe
Old Mar 2, 2004 | 12:34 PM
ScoobyBoy's Avatar
i got a cel from my uppipe 10k down the line. id recommend that you screw in the hole, and use the resistor mod from the get go, so you dont have to worry about it later on.
Old Mar 2, 2004 | 01:38 PM
esracer's Avatar
Will the mechanical cel fix work with the up-pipe also just like the downpipe, instead of the resistor fix. I really don't like the idea of cutting into wires, I'll will stay away from that as much as possible.
Old Mar 2, 2004 | 01:49 PM
The uppipe CEL fix is just plugging the resistor into the plug that the EGT goes into. No permanent modification required.
Old Mar 2, 2004 | 02:24 PM
ScoobyBoy's Avatar
i dont think anyone has tried the mechanical fix yet. but honestly theres no point. the resistor mod costs $.99 and all you do is plug it in. very simple. gluck
Old Mar 3, 2004 | 12:40 PM
esracer's Avatar
Thanks again for the info, I'm guessing I can just get the new gaskets from a subaru dealership?
Old Mar 3, 2004 | 05:41 PM
Yes, they are inexpensive. I think Gruppe-S also has them in stock and at a good price.
Old Mar 4, 2004 | 02:05 PM
esracer's Avatar
Thanks for the info again
Old Mar 4, 2004 | 02:43 PM
Daredevil's Avatar
i didn't get a cel with my helix up and down pipe
then again, i had a cel fix for the dp D:
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
John Kim
Aug 22, 2004 01:48 PM
