unstable warm start idle?
Old Feb 24, 2005 | 06:01 PM
mins's Avatar
Car Info: 02 Subaru WRX Sedan
is this happening to every wrx owners?
mine's 02 wrx.
when i turn it on, rpm goes up n down to about 650 rpm.
it's happening only when it's enoughly wormed up.
i thought it's from the aftermarket bov,
but today i put it back to the stock bov.
same happening.
better than turboxs.
when i had it, it hits 400 rpm n goes up.
i have hks turbo timer, so i could read the exact rpm.
Old Feb 24, 2005 | 06:12 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
Hope this helps
Originally Posted by BANSUVS
Pretty much every fuel injected car should idle at ~1500 rpm when cold, and slowly decrease as the coolant warms up. Normal warm idle is about 650 rpm.
https://www.i-club.com/forums/showth...light=idle+rpm
Old Feb 24, 2005 | 06:47 PM
turfshark's Avatar
if you are getting "wormed" up, i would really seek the advice of a doctor.
Old Mar 6, 2005 | 01:56 AM
teck7droid's Avatar
Car Info: 03 pearl black wrx
bumb I have that same problem.
I think you guys misunderstood his concern. Heres what i think hes saying
When first starting the wrx after being turned off and long period of time probably over 2hrs. The car starts right up! just normal the rpms are perfect were they should be.
You then drive around for a while lets say 30mins. Then you turn off your car and go to the store to get some grocerys. When you fire the car up again. The very first initial Rpm Shoots up normally but IMMEDIAETlY Falsl low below normal rpm at idle, The car shakes more then ususally for acouple of pulses and right before I thinK its going to die it Stableizes.
My mods are full turbo back and utec thats proffesionally tuned.
I notice this situtation most Dramatically when im using the utec. When I switch the map to stock, It still happens but not nearlly as dramatic.
I guess it has something to do with the utec, Or unburnt gasoline because when i feel the rpms following dangerously low I blimp the gas to about 2.5k and i get loud exhaust popping noises. I Guess its unburnt fuel thats poping.
I have a Greddy Evo, and im running no cats. I seldomly hear backfires (pops) when driving or in between shifts. But Every time I start my car after being driven, I can always make it backfire by blimping the gas
I blimp the gas because i was affraid the car would turn off, But even if i dont blimp the gas It will stableize no mater how rough the idle gets for acouple of Pulses.
So in other words I get it also, But I have i feel it alot more with the Utec
dthack03
Apr 23, 2014 08:02 AM
b3atbxr
Jun 18, 2007 08:28 AM
red wrx
Feb 14, 2007 02:45 AM
KOSTI
Jan 12, 2007 11:04 AM
WRX lova
50
Dec 18, 2003 10:51 PM
