Unorthodox Lightweight Pulleys
Old Mar 26, 2005 | 05:30 PM
Mike79M's Avatar
Car Info: '02 WRX, HKS Up/Down Pipe, HKS Exhaust, AEM Intake, GReddy BOV
Aloha All Again!
Another question. Has anyone installed Unorthodox Lightweight Pulleys (Crack, Alt, Power Steering) on thier WRX? I'm having problems getting the power steering pump pulley off and wonder if anyone has had to go through with the frustration of putting these on. And what you did to get it back on. Thanks again...
Matty
Old Mar 26, 2005 | 10:00 PM
Wingless Wonder's Avatar
Moved thread to Impreza EJ20T engine forum from General.
Sorry, I had only an underdrive crank pulley installed by a shop so no experience with those other two.
Old Mar 28, 2005 | 12:57 PM
cdawg's Avatar
Car Info: 05 SLK 350
I have not had experience with those specific pulleys, but I have had the unfortuate displeasure of having to change PS pulleys before. They are typically pressed on, so you may need to enlist the usage of a PS pulley puller. You can typically rent/borrow one. If you are not familiar with it, it will usually have 3 hooks that latch onto the pulley and a drive that presses the shaft away from the pulley. Hope this helps.
Old Mar 30, 2005 | 06:54 PM
Mike79M's Avatar
Pulleys...
Thanks for hte insight. I'll check that out.
jung187
Nov 1, 2010 08:01 AM
FW Motorsports
Engine and Drivetrain
May 24, 2007 09:18 AM
1SIKBRU
Jun 11, 2005 08:25 PM
Orbiter
Nov 14, 2004 05:24 AM
JamesGRrallye
Apr 6, 2003 11:02 PM
