To underdrive or not? Pulley Sets
Old Aug 31, 2003 | 09:58 PM
Blarg's Avatar
i thought that the stock pulley BECAUSE its heavy WAS in itself a dampener. Just save your money and get a Porshe.
Old Sep 1, 2003 | 06:01 AM
ride5000's Avatar
Originally posted by BAN SUVS
Personally, I believe the risk of damaging your crank bearings outweighs what small gains are to be had with the pulleys. It's a better idea to save up and do it right with a new flywheel.
how does the lack of damper cause bearing failure?
the crank itself, i can see, but the bearings?
and, how does lightening the rotational inertia at one end of the engine differ from doing it at the other? in other words, how does a lightened flywheel cause no problems, whereas a lightened pulley does? (in fact, it seems to me that they should be/would be matched to each other.)
no vitriol here, just honest questions.
ken
Old Sep 1, 2003 | 01:38 PM
The small rotational vibrations of the crank, when they are not sufficiently dampened, cause small spots to wear in the crank bearings. They eventually wear down enough to get out of round, and cause even more problems, leading to excessive clearance between the crank and bearing. It's the bearings that actually take the punishment of the vibrations in question. The reasont the flywheel is better is that the typical lightweight flywheel is still 12 pounds, which is plenty for dampening the vibrations on that end of the crank. If you read Mike Shields' article that was linked to by Nate0125RS, you'll see why it's better to stick with the stock. The other reason is the siple fact that you are unlikely to be able to tell the difference between a 12 pound flywheel and stock pulley versus a 12 pound flywheel with a lightened pulley- it just isn't really worth the $100 at that point unless you are modded to the max and need every last hundredth on your E.T. While a lightened flywheel costs roughly 4 times as much as a pulley, it's WAY more effective at increasing throttle response, plus it is easier on your gears. The bang-for-the-buck is actually better with the flywheel than with a pulley.
Old Sep 3, 2003 | 09:22 AM
ride5000's Avatar
hmm...
well, i still have yet to hear of someone's engine failing from EITHER crankshaft failure OR bearing wear/tolerance... it seems the bottom ends of these boxers are pretty tough.
i just don't think the use of UD/LW pulleys is nearly as severe a problem as folks theorize it to be. if it were, SURELY we would have heard something by now, right?
imo, if you're looking to get 200k mi out of your original engine, drive it like grandma and don't mod it. otherwise, be aware that just about 99% of the mods you do to your car have a negative impact on longevity.
jm2c
ken
QuickShift
Mar 26, 2004 09:11 AM
FlaBrit
Feb 13, 2003 04:16 PM
MPOWERD
Feb 12, 2003 09:06 PM
FlaBrit
Feb 8, 2003 08:22 PM
QuickShift
Dec 13, 2002 09:57 AM
