Twin dump or bellmouth?
Originally posted by simpwrx02
if you want to pass a visual inspection just get some heat shields in place where the 3rd cat should be.
I'm getting one in two weeks, instead of a high-flow cat.
Car Info: 02 PSM WRX
if you want to pass a visual inspection just get some heat shields in place where the 3rd cat should be. Im pretty sure wrx's arent popular enough yet that every mechanic knows it has 3 cats. Also if you have a utec you might be able to make a smog map...aka program computer to help you pass smog.
I dont have to worry about the visual but thanks for the info.
both stomrung and bosal make twin dump downpipes that retain the third cat.........I went with the bosal because it rejoins further down than the stromung does. Can't say if it passes visual (I do have the stock mid-pipe) but it was the best compromise for me.
visual is no problem at all.
I went by a place where they do testing and one of their testers came out to look at my car, he had never seen a wrx before under the hood, and was quite impressed.
you just have to find the guys that don't know their head from the hole they have stuck it in.
con10der_8
Aug 26, 2014 09:23 PM
Dinko81
Jun 25, 2004 10:58 AM
ENess76
Oct 3, 2003 08:25 PM
GDA
Feb 28, 2003 06:46 PM
blackwagonrx
Feb 10, 2003 12:25 PM
