Turbo Timer question
Old May 8, 2003 | 02:19 AM
kyoung05's Avatar
Here is a link to a post on a different forum that goes step by step to install the Blitz turbo timer w/ boost gauge with the wiring harness.
http://forums.nasioc.com/forums/show...tz+turbo+timer
Although you have the Greddy one, I'm sure all of the steps will be the same, with the exception that you can omit the boost gauge stuff. I installed my turbo timer about 2 months ago, and it was a pain in the *** at first. It takes some time locating what exactly it is they are talking about. First, the blue clips the wiring harness plugs into is not directly underneath the steering column. Since you should have all of that plastic trim and lower steering column pieces removed anyhow, the blue clips are more to the right, and are pretty hard to reach. They are by/under this metal bar/strip. Just look at the far right, underneath the steering column, more towards your center console and you should see it. They are a pain in the *** to unclip btw, so have patience. Also, I was never able to find that pinkish wire they were talking about by the e-brake, so I just grounded the purple wire to a screw. The keyless entry removal is pretty self-explanatory. Good luck.
________
AMATEUR UPLOAD
UnknownAlly
Nov 4, 2011 10:54 PM
Sti"izzle"
Jun 6, 2006 12:21 PM
Dirty Sanchez
Dec 28, 2005 02:08 PM
wombatsauce
20
Jan 19, 2003 05:53 PM
Vidiotgamer
Jan 5, 2003 12:29 AM
