Turbo install with low boost numbers..???
Old Oct 8, 2011 | 10:09 AM
dscoobie's Avatar
Car Info: 2004 Subaru Impreza Wrx
Hey,
Had Grimmspeed do port and polish job on my stock 04 wrx turbo. Did the install once and had coolant leak. Uninstall then a re-re install and no coolant leaks. I'm now running into the problem of not hitting correct boost numbers. Ran cobb v2 stage 2 91 tune and only hitting 8psi max........ Turbo seems to be running fine, and exhaust leaks don't seem to be present. Checked vacuum lines as well and it all seems to be fine.
Any suggestions?
Thanks,
Old Oct 8, 2011 | 03:37 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Resteictor pill installed correctly?
Old Oct 9, 2011 | 06:05 PM
dscoobie's Avatar
May have a small exhaust leak downpipe to turbo. That worked though. I'm hitting 14.4psi now so i'll check again but its better than it was.
djwonder925
Apr 21, 2013 12:05 AM
DesertMetallicA
Jan 4, 2006 01:19 AM
03SubaWRX
Feb 7, 2004 09:22 AM
Shaitiger
Apr 2, 2003 12:09 AM
Shaitiger
Mar 30, 2003 11:22 PM
Top
