Turbo bogs at high rpms
Old Nov 21, 2008 | 09:36 AM
lanz0r's Avatar
Car Info: Blown Transmissions
My brothers 02 wrx has 8k miles on it, when boosting at about 5k rpm the turbo bogs down and it feels like if you were to let off the gas and back on intermittently. It pulsates slowly and the turbo gauge jumps up and down from about .00 to 1 bar, I don't think its a vaccum leak because it boosts just fine until 5k, people have told me its a fuel cut, or overboost, but I'm pretty sure it ain't overboosting.
Old Nov 21, 2008 | 10:19 AM
03_Impreza_Al's Avatar
Pull the map off of the ECU.
Is it on the stock TD04?
Who knows what people do with their subarus these days. It's really scaring buy a used one.
Old Nov 21, 2008 | 10:21 AM
lanz0r's Avatar
its completely stock, he hasnt done anything to it.
lanz0r's Avatar
he bought it brand new also.
Old Nov 21, 2008 | 10:22 AM
lanz0r's Avatar
note I said 8k miles not 80k. the car was sitting for about 6 years.
Old Nov 21, 2008 | 10:48 AM
Could be a lot of stuff like the fuel pump and or injectors going bad. Take off the intercooler look for tears. Maybe the cat in the uppipe is shot.
So you got a couple choices take it to a shop or problem solve yourself good luck!
Old Nov 23, 2008 | 12:24 PM
meilers's Avatar
If it sat for six years, you've probably got cracks and issues with nearly every gasket and hose in the vehicle. Our Legacy GT wagon sat for two years, and had cracked CV boots, head gasket, valve cover gasket, radiator hoses and vacuum line issues. Anything that is used to having grease in it or fluid in it or being under pressure/vacuum needs to actually have that movement/fluid/pressure in it on occasion in order to not crack or harden up to sludge. You could have corroded injectors; you could also have coolant or oil sludge in the block, and at high RPMs you're getting a big temp spike. I doubt it is the up-pipe cat, those are made of palladium (non-rusting) and can outlast the car at normal boost. My guess is you have a tear in your air intake path, or a block in the coolant lines to the turbo, or a bad MAF sensor.
Old Nov 23, 2008 | 12:59 PM
vangstaboi86's Avatar
Car Info: 04 sti
you should do a compression test...
Old Nov 23, 2008 | 01:28 PM
wrxisthebest's Avatar
wow, um ya, if it sat for 6 years... ur looking at possible crazy issues...
it could be because u threw that BOV on there.....
Old Nov 24, 2008 | 07:55 AM
lanz0r's Avatar
It was doing it before, I let my friend borrow the BPV and put on his BOV lol...
Old Nov 24, 2008 | 08:30 AM
VRT MBasile's Avatar
is it like the RPMs go up a few hundred, pause, and then go up a few hundred more, and then pause again? Thats what mine did. I don't know what the problem was (car had 19k miles on it when I got it) but getting tuned by Ed fixed it. The Cobb map lessened the problem, but didn't resolve it completely.
Old Nov 24, 2008 | 09:19 AM
lanz0r's Avatar
That's exactly what it does
Old Nov 24, 2008 | 11:21 AM
is it an auto tranny or manual? Mine was an auto and the dealership said it "is the tranny protecting itself from the power of the [stock] engine." I called BS on that. When I had it converted to a manual (no more TCM) it still had the same problem. Bottom line is get a good custom tune. I suggest Ed of EQTuning.
Old Nov 24, 2008 | 01:29 PM
07Blueru's Avatar
Car Info: 07 Blue WRX Impreza TR
We had the same problem with an evo last year and there was a boost leak in the innercoolar piping. Might want to check that, but if it was sitting for a lot of years. You could have a lot of problems with it.
