torque specs?
Old Sep 13, 2009 | 12:29 PM
wrxisthebest's Avatar
torque specs?
hi,
I need to know the torque specs on a couple thing for my 2003 wrx.
main bearings=?
oil pickup=?
oil pan=?
thanks
ryan~
Old Sep 14, 2009 | 01:51 PM
bump please help me out...
Old Sep 15, 2009 | 12:06 PM
help please and thank you
parts arrive on thursday so i need them asap
Old Sep 15, 2009 | 09:47 PM
DUB's Avatar
DUB
Car Info: 03 Wagon
Do you not have a factory service manual?
Old Sep 15, 2009 | 10:08 PM
stirs's Avatar
Car Info: 2000 2 door RS/ daily driver vtech
wow...I under stand for the bearings but for the little 10's of the pick up and pan???? just trust your gut on those and I think the mains have to be 42p or 44p...................ok here you go if you want to be more specific...
oil pan bolts go to 3.6 ft-bl
oil pick up goes to 7 ft-bl
main bearings goes to 32.9+1.1 ft-bl
hope thats helps...good luck
Old Sep 16, 2009 | 01:31 PM
ya, i was guessing the oil pan and pick up were low...
do you happen to have the rod bearing specs as well?
Thank you alot man
Old Sep 16, 2009 | 05:10 PM
stirs's Avatar
my bad..those are the rod ones...as for the mains its 34.7+2.2 ft-bl for the ones that go on the sides by the heads(big bolts with washers) for the ones on top of the block and the front and back its 18.1+1.4 ft-bl except the one in the back bottom that one goes to 4.7 ft-bl....these are the bolts that connect the 2 parts of the block it self....hope it helps
Sokana
SoCal Classifieds
Jan 11, 2008 08:31 PM
dropkick_muppet
Aug 30, 2003 08:35 PM
pathfinder2
Aug 6, 2003 05:52 PM
dropkick_muppet
Jun 13, 2003 10:40 AM
fastnoypi
Feb 11, 2003 06:15 PM
