Torque specks for rear o2 sensor
Old Dec 19, 2002 | 03:42 PM
Andersonwrx's Avatar
Car Info: '02 WRX TurboXS Stage 4
Does any body know the torque spect for the rear o2 sensor on the WRX.
Thanks.
Old Dec 19, 2002 | 07:15 PM
OakosAutomotive's Avatar
Car Info: 2002 WRX OAKOS Edition
The FSM says it should be tightened to 15.2 ft-lbs
It also recommends applying a small amount of anti-seize compound to the threads.
-Dave
Old Dec 19, 2002 | 08:39 PM
stealth-wrx's Avatar
make sure you use anti-seize as he said, it will kick you in the butt later if you don't.
Old Dec 21, 2002 | 01:06 PM
I use Permatex. There are lots of companies that make anti-seize compound. Loctite is another that comes to mind.
Permatex has three different kinds of anti-seize lubricants:
Regular compound is good to 1600°F
Copper compound is good to 1800°F
Nickel compound is good to 2400°F
http://www.permatex.com/products/pro...lty+Lubricants
You should be able to find these in your local autoparts store.
-Dave
polishwrex
Jan 7, 2009 12:25 PM
Peaty
May 30, 2008 09:58 AM
NorCalDC5
Jul 22, 2007 11:44 AM
Wildblitz1337
Feb 18, 2006 06:35 PM
05wrx
May 5, 2005 07:35 AM
