timing belt help - possible interference while hand-turning engine
Old 10-09-2007, 06:39 AM
Wagon Joe's Avatar
Car Info: '04 WRX Wagon in Blue
Exclamation timing belt help - possible interference while hand-turning engine
This is on a 2004 WRX.
I installed a new water pump, timing belt tensioner, all new idlers, and timing belt, ensuring the timing marks were correct. I did not release the tensioner pin yet. I put the shifter in neutral, and hand turned the assembly with a large ratchet. I was able to smoothly turn the assembly for 2 rotations of the entire timing belt. During the 3rd rotation, it felt like I hit a wall. When this happened, the assembly was exactly 6 1/2 teeth before the timing belt installation position (see sketch below), and everything was correctly in time. What could be happening?
NOTE: the spark plugs are removed, and this felt a lot different than the spring tension of the valves during the prior 2 rotations.
Any ideas, insight, or advice? Thanks so much!
- Joe
Position of potential interference:
Wagon Joe is offline
Old 10-09-2007, 11:02 AM
this is a good one
you got the T belt to go around three times then bam it wont move?
sigma pi is offline
Old 10-09-2007, 02:38 PM
Wagon Joe's Avatar
yeah crazy, I know... the only possible explanation I can think of is that it jumped teeth during my manual rotations since I didn't have the tensioner unpinned. I need to double-check the timing marks and I guess remove the belt and try again.
Old 10-09-2007, 02:53 PM
hmm yeah thats actually a GREAT idea
the tension can be corraled back in if you have a vice
you can put the pin back in
so its not irreverseable like a grenade haha jk
sigma pi is offline
Old 10-09-2007, 03:59 PM
iClub Silver Vendor
FW Motorsports's Avatar
Car Info: 2005 LGT wagon
That's a big misconception about hand grenades.
You can pull the pin out...and as long as you do not allow the handle to fly off, the pin can be re-inserted & the grenade saved for another day.
BTW...re align all the marks, pull the pin, and rotate the crank.
FW Motorsports is offline
Old 10-10-2007, 05:59 AM
Wagon Joe's Avatar
Good news! I was just being paranoid. When I got home from work the engine turned over just fine. At the "wall-like" point, it helped to back the engine up a bit and then turn it with a little momentum.
I backed up the engine to the installation point and all of the timing marks were lined up, so I think I'm good to pull the tensioner pin, turn it over a few more times, and put everything back together.
Old 10-10-2007, 08:38 AM
close enough haha
close only counts............
sigma pi is offline
Old 10-10-2007, 09:54 AM
iClub Silver Vendor
So, have you started the motor yet?
Old 10-10-2007, 11:09 AM
Wagon Joe's Avatar
nope, bad weather and no garage has kept me from putting it all back together. I'll post an update once I start her up.
Old 10-10-2007, 03:03 PM
make a grenade thread
motor/weapon
sigma pi is offline
Old 10-11-2007, 08:35 AM
Wagon Joe's Avatar
Finished the job last night, runs great!
tripod023
03-21-2010 08:58 PM
unstble
03-21-2008 09:09 AM
ej20boost
08-07-2006 05:16 PM
Quick Reply: timing belt help - possible interference while hand-turning engine
Top
