timing belt help - possible interference while hand-turning engine
1 Attachment(s)
This is on a 2004 WRX.
I installed a new water pump, timing belt tensioner, all new idlers, and timing belt, ensuring the timing marks were correct. I did not release the tensioner pin yet. I put the shifter in neutral, and hand turned the assembly with a large ratchet. I was able to smoothly turn the assembly for 2 rotations of the entire timing belt. During the 3rd rotation, it felt like I hit a wall. When this happened, the assembly was exactly 6 1/2 teeth before the timing belt installation position (see sketch below), and everything was correctly in time. What could be happening? NOTE: the spark plugs are removed, and this felt a lot different than the spring tension of the valves during the prior 2 rotations. Any ideas, insight, or advice? Thanks so much! - Joe Position of potential interference: [ATTACH]177065[/ATTACH] |
this is a good one
you got the T belt to go around three times then bam it wont move? |
yeah crazy, I know... the only possible explanation I can think of is that it jumped teeth during my manual rotations since I didn't have the tensioner unpinned. I need to double-check the timing marks and I guess remove the belt and try again.
hmm yeah thats actually a GREAT idea
the tension can be corraled back in if you have a vice you can put the pin back in so its not irreverseable like a grenade haha jk |
That's a big misconception about hand grenades.
You can pull the pin out...and as long as you do not allow the handle to fly off, the pin can be re-inserted & the grenade saved for another day. :) BTW...re align all the marks, pull the pin, and rotate the crank. |
Good news! I was just being paranoid. When I got home from work the engine turned over just fine. At the "wall-like" point, it helped to back the engine up a bit and then turn it with a little momentum.
I backed up the engine to the installation point and all of the timing marks were lined up, so I think I'm good to pull the tensioner pin, turn it over a few more times, and put everything back together. |
[QUOTE=Paul@dbtuned;2000061]That's a big misconception about hand grenades.
You can pull the pin out...and as long as you do not allow the handle to fly off, the pin can be re-inserted & the grenade saved for another day. :) BTW...re align all the marks, pull the pin, and rotate the crank.[/QUOTE] close enough haha close only counts............ |
[QUOTE=Wagon Joe;2000590]Good news! I was just being paranoid. When I got home from work the engine turned over just fine. At the "wall-like" point, it helped to back the engine up a bit and then turn it with a little momentum.
I backed up the engine to the installation point and all of the timing marks were lined up, so I think I'm good to pull the tensioner pin, turn it over a few more times, and put everything back together.[/QUOTE] So, have you started the motor yet? |
nope, bad weather and no garage has kept me from putting it all back together. I'll post an update once I start her up.
[QUOTE=Paul@dbtuned;2000735]So, have you started the motor yet?[/QUOTE]
make a grenade thread motor/weapon |
Finished the job last night, runs great!
