timing belt help - possible interference while hand-turning engine
Car Info: '04 WRX Wagon in Blue
This is on a 2004 WRX.
I installed a new water pump, timing belt tensioner, all new idlers, and timing belt, ensuring the timing marks were correct. I did not release the tensioner pin yet. I put the shifter in neutral, and hand turned the assembly with a large ratchet. I was able to smoothly turn the assembly for 2 rotations of the entire timing belt. During the 3rd rotation, it felt like I hit a wall. When this happened, the assembly was exactly 6 1/2 teeth before the timing belt installation position (see sketch below), and everything was correctly in time. What could be happening?
NOTE: the spark plugs are removed, and this felt a lot different than the spring tension of the valves during the prior 2 rotations.
Any ideas, insight, or advice? Thanks so much!
- Joe
Position of potential interference:
- Joe
yeah crazy, I know... the only possible explanation I can think of is that it jumped teeth during my manual rotations since I didn't have the tensioner unpinned. I need to double-check the timing marks and I guess remove the belt and try again.
hmm yeah thats actually a GREAT idea
the tension can be corraled back in if you have a vice
you can put the pin back in
so its not irreverseable like a grenade haha jk
iClub Silver Vendor
Car Info: 2005 LGT wagon
That's a big misconception about hand grenades.
You can pull the pin out...and as long as you do not allow the handle to fly off, the pin can be re-inserted & the grenade saved for another day.
BTW...re align all the marks, pull the pin, and rotate the crank.
Good news! I was just being paranoid. When I got home from work the engine turned over just fine. At the "wall-like" point, it helped to back the engine up a bit and then turn it with a little momentum.
I backed up the engine to the installation point and all of the timing marks were lined up, so I think I'm good to pull the tensioner pin, turn it over a few more times, and put everything back together.
close only counts............
iClub Silver Vendor
Heedz
Mar 15, 2015 04:32 PM
CCC
Engine and Drivetrain
Feb 2, 2012 10:09 AM
unstble
Mar 21, 2008 09:09 AM
