T67?
Old Jul 29, 2004 | 03:53 PM
Mister 2's Avatar
I'm sure it'll work but there will be a lot of turbo lag. The extra displacement of the STi motor will help a bigger turbo spool quicker.
Old Jul 29, 2004 | 04:00 PM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
There's no point in putting a T67 on a stock wrx motor. The motor won't be able to spool that turbo at all. Get a FP Green if your looking for great top end.
Old Jul 29, 2004 | 04:23 PM
SsTiNgEr77's Avatar
Car Info: 2002
dont get a green on a 2.0 unless you are loaded
get an 18g with an IC
Old Jul 29, 2004 | 06:33 PM
dan avoN7's Avatar
Originally Posted by ppat
the engine would be modded of course. I just dont see how its so easy to stick t78 and such turbos on cars like rx7s. I know there egines arent stock and I know a stock wrx wont spool it either. Just wondering if it was possible at all with ever mod imaginable to put a t78 or 88 on a wrx. And I know pretty much no part would be stock on the engine for this also.
The answer is no. The only way to realistically run that turbo is with more displacement then a 2.0. You have to understand that even though rotary engines are small they produce alot of power and flow alot more air than ej20 motors do. So even though the rotary is somewhere around 1.3liters the amount of air it flows is equal to a 2.6-2.7liter motor. That is why that engine can run a t78 or t88.
Old Jul 29, 2004 | 07:47 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Twin T78's on RX-7? Nobody does it. They have single T78 and T88 kits for that car, but not the twins. Unless in it is a Cosmo 3-rotory engine, but they there will be no room.
I am running T67 kit on my WRX with a 10 cm^2 housing.
That kit made 305 wheel horsepower on Shiv's Dynamic Dyno on pump gas. It spooled up at around 5000RPM but the kick in the nuts is crazy after that. That is by no means an auto-x turbo.
Then I got a built motor and easily made about 20 horsepower more, much more torque and much less lag. Still on CA sucky pump gas.
Now I am building the motor even more so more power is in the works.
In the meantime, I got myself a nice JDM EJ207 w/ AVCS so we'll see how that works.
Old Jul 29, 2004 | 11:11 PM
Imprezer's Avatar
Admin v2.0
Of course.
I did re-do the downpipe and uppipe adapter it came with.
The dp it came with was probably made for a 1.2 Civic or some ****, because it is like 1.75". The uppipe adapter was even worse. I will show pics later. I used BOZZ Speed GC8 uppipe adapter (which will work 4 u) and modded it to clear the firewall. Also, I routed the wastegate back into the downpipe. So, it all should be good.
Old Jul 30, 2004 | 01:19 AM
Imprezer's Avatar
Admin v2.0
The BOZZ Speed turbine adapter includes uppipe. It is one peice. I am not sure if they still make it. You can check, hehe. You are in Japan. They used to sell it as a part of their 20G turbo setup kit.
Old Jul 30, 2004 | 11:33 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
'neversatisfied' threw that on his stock wrx + stock fuel + no EMS and ran a 12.6 @ 107 with the stock trans. Sounds pretty ****in' harsh and stupid but take it as it is. Now he's building his stuff and I'm sure an 11 second pass is quite easy.
Old Jul 30, 2004 | 07:53 PM
Imprezer's Avatar
Admin v2.0
Really?
I ran 12.6@112 with US EJ20, FMIC and TECIII with it. That was when I made the torqueless 305hp in the begining.
So I guess that is pretty much it's limit on a stock EJ20.
superfly
Jun 2, 2004 09:41 PM
areg
Feb 5, 2004 12:07 AM
superfly
Jan 22, 2004 03:49 PM
superfly
Dec 19, 2003 07:50 PM
Boosted Wagon
17
Dec 9, 2002 02:33 AM
