suspension swap?
Old Oct 9, 2004 | 01:04 PM
cabe's Avatar
Car Info: 99 subaru impreza 2.2L coupe
Question suspension swap?
Hey ya'll.
Will an STi suspension be a direct fit replacement for my stock 03 wrx suspension?
Old Oct 9, 2004 | 01:45 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
I think you need to keep the 03 top hats.
Old Oct 9, 2004 | 02:04 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
If it is from the 04 STi then it will bolt right in, assuming you are talking about shock/spring/top mount.
The 05's will not work for you.
Old Oct 9, 2004 | 07:09 PM
cabe's Avatar
Thanks guys. Windingroad, why do you think I should keep the stock sus. on there? STi suspension would be, well, better.
Old Oct 9, 2004 | 09:43 PM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
He means if you are using the 04 Sti suspension you need to use the top hat of the suspension. Part that is connected to the shocks and spring and the chasis of the car. If you are using 02-03 Sti suspension you should be fine ....
Old Oct 10, 2004 | 01:11 AM
Imprezer's Avatar
Admin v2.0
There is no 03 STi and he does not need diff top hats.
Top hats are only needed if you are using 02-03 springs on 04 or vice versa.
PacificLegacy
Aug 26, 2014 09:54 PM
ch0g
Aug 27, 2006 06:14 PM
XFADE
Jan 27, 2004 02:00 PM
DoomE.Q.
Nov 27, 2003 08:55 PM
Imprezzive
Mar 28, 2003 09:38 PM
