Strange noise??
Old Sep 16, 2004 | 11:07 PM
Double Helix's Avatar
Car Info: E39 M5
Strange noise??
I am getting a strange buzzing noise when I accelerate hard. The sound starts at about 3500 and fades out around 5000 rpm. It's sounds like its coming from the passenger side of the car. All I have is a catback, removed silencer with K&N, COBB AP stage 1, and a GFB BOV. I was thinking it could be just intake noise from the removed silencer. Does anyone have any ideas?
Old Sep 17, 2004 | 04:16 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I doubt this is it but Subaru has a recall on the passanger seat. The bolts loosen over time and I would think a loose seat could possibly make a buzzing sound.
Old Sep 17, 2004 | 05:27 PM
MO REX's Avatar
Originally Posted by ppat
this is more of a high pitched humming noise. when it first happened i was going 135, so i thought i blew my turbo, but then i hear all kinds of stories on here about eveyone elses doing it too. i think it has to do with that flat intake above the grill going into the fender well. because that wraps around and looks like it might be causing the noise in the passenger door. but i wish someone could tell us exactly what it was.
I dont think you are talking about the same noise that he is since your noise is at high speeds and his are at certain RPM's and it goes away at 5k. I dont know that this is true but I heard that the mysterious high speed noise that you are talking about is from the side mirrors but if it was you would think you would also hear it on the drivers side.
Old Sep 17, 2004 | 11:05 PM
sssp's Avatar
Car Info: 2004 WRX
This exact same thing happens to me too...and just about the same RPM also.
But mine started to happen after I removed the whole center console to install my short shifter and TT. So I am guessing something is ratteling in there.
Old Sep 19, 2004 | 10:59 AM
Car Info: E39 M5
I think I found it. The rattling was coming a section of the silencer that I used to rout cold air from the fender. When I removed it the noise stopped. As for the high speed issue. Well I have not yet been above 120 so if a sound should occur at that speed I will let you all know.
STi4life
Mar 1, 2004 11:09 AM
osidescooby
Dec 22, 2003 10:52 AM
VitaminWRX
Nov 1, 2003 12:58 AM
ppat
Sep 12, 2003 08:34 PM
boynty77
Dec 24, 2002 10:13 AM
