Stock Turbo
Old Jan 24, 2004 | 12:14 PM
If you are at high altitude, not very long. If you're close to sea level, then it will be fine. The reason is the fact that turbos have to spin much faster at high elevation (low barometric pressure) to produce a given amount of boost. This results in overspeeding the wheels, which will bake your center section. However, on an EJ20, 18 psi is out of the TD04's efficiency range. you won't be making any more power on 18 psi than you would at 16 psi.
DemonPossessed
Nov 13, 2012 11:22 AM
JDMGC8
May 29, 2009 08:07 PM
latinskllz
Jan 27, 2004 07:36 AM
bluesubeguy
Oct 4, 2003 03:26 PM
singsing
May 24, 2003 03:19 AM
