stock exhaust gas temp sensor
Old Jan 15, 2003 | 04:30 PM
fastnoypi's Avatar
Re: stock exhaust gas temp sensor
Originally posted by wrx137
does anybody know where it it located ....
the probe is in your upipe...you can trace from one of the 3 wire harness that are mounted next to your boost solonoid
Old Jan 16, 2003 | 06:03 AM
fastnoypi's Avatar
Originally posted by LTrainSVT
I thought cold air intakes were supposed to lean your mix out, while running the stock ecu
Larry
correct..it does lean out your mix to a point ..the ecu will learn the lean mixture and eventually accomodate by dumping more fuel.
Old Jan 17, 2003 | 10:32 PM
Wingless Wonder's Avatar
i also read that other guys on other forums (impreza.net) are having the same problem and same mods mostlly the running the injen intake and no ecu or injectors or things like that to even the effect...
same hesitation and they dont know what the problem is either
See Shiv's (Vishnu Performance) take on the subject of cold air intakes (CAI):
https://www.i-club.com/forums/showth...5&pagenumber=2
__________________
ww
Island Style
May 26, 2006 08:59 AM
gordy
Oct 27, 2004 03:03 PM
kidatari
Sep 9, 2004 12:22 AM
bambams247
Aug 21, 2003 08:34 AM
teamugi
Wanted
Dec 2, 2002 02:16 PM
