Stock Catback restrictive?????
Old Jan 3, 2006 | 02:52 PM
WRXLAD's Avatar
Is it very restrictive???? the reason I ask is that I'm going fully catless with a helix downpipe, but for noise reasons I was going to mate it to the stock catback. I'm also running an up-pipe and Ecutek.
Will I lose much of the catless gains???? or is it like the airbox where it won't matter until I'm running big power???
TIA
Old Jan 4, 2006 | 01:23 PM
subie OCD's Avatar
Car Info: 04 STi
If you're fully catless it wont make much of a difference
Old Jan 4, 2006 | 01:47 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
im fully catless and i felt a difference..it doesnt pull as hard because the stock catback piping is thinner than the downpipe. ive have many different catbacks and HKS gets the most power..i have a borla hush now for sound reasons and it sounds great, not loud until you step on it and the power is still there. ive also had a GReddy Evo2.
Old Jan 4, 2006 | 03:45 PM
glenspen's Avatar
Car Info: 05 WRX
I sense a disagreement of opinion.
Old Jan 4, 2006 | 04:59 PM
kumaWRX's Avatar
Car Info: 04 Toyota Tacoma
Imho, noticed a lot less restriction when I had just my Blitz Nur Spec axle back on a fully stock car. Boost came in quicker and the car was much more responsive.
Old Jan 4, 2006 | 05:39 PM
Wingless Wonder's Avatar
Using the stock catback on a free-flowing exhaust will be somewhat restrictive. There will still be improvement from a good downpipe and midpipe system, even with a stock or quiet aftermarket catback. If you must have a restriction, it's best that it be as far away from the turbo as possible (like a catback). By then, some of the exhaust has lost velocity and cooled down.
My car has a stock turbo, downpipe, and midpipe (3rd cat) and was dyno tuned with that combination. After switching to a Strömung 3" dual tip catback, I was able to improve my ¼-mile E.T. by 2/10ths of a second with no other changes. I did notice, however, that my trap speed (which indicates horsepower) dropped by one mph, indicating that the power gain was in the mid-range. A visit to my tuner and a quick reflash regained the top end trap speed and resulted in yet another couple of tenths from my E.T. His opinion was that the new catback caused a top end lean condition because it a less restrictive exhaust may necessitate a slight richening of mixture at full-throttle, while at the same time require less ignition advance, IIRC.
While your results may vary, I'm convinced that a catback is important to a free-flowing exhaust system.
Old Jan 16, 2006 | 02:47 PM
illusion's Avatar
Car Info: '09 accord, '14 2 seater chevy
TONS of restriction, at least my 05 was. It might not be a problem with the stock turbo, but I went through a PITA with a VF34, PDE Up, Madded Catted DP, 3CE, halfback and stock axleback. Long story short, picked up about 20whp and 18lb-ft on the gruppe-s dyno going from halfback and stock axleback to Borla "hush" catback.
JourdanWithaU
Dec 6, 2012 06:35 AM
brucelee
Mar 7, 2009 04:43 PM
strider327
Jun 25, 2007 03:53 PM
speedfreak
13
Feb 2, 2005 08:50 PM
Mat - 98 R/T
20
Aug 9, 2004 12:26 AM
