Is this STI upipe defective?
Old Aug 29, 2004 | 02:30 PM
MO REX's Avatar
Car Info: 02 PSM WRX
There are two spots like this inside the pipe. I guess this is from the weld that holds the heat shield on. Do you guys think I should return it or just grind these spots smooth with a dremmel tool?
Thanks.
Old Aug 29, 2004 | 04:37 PM
RoadSpike's Avatar
That thing is so tiny i can't imagine it having any effect at all on your performance in general.
I wouldn't touch it if it doesn't leak just keep it.
Old Aug 29, 2004 | 04:39 PM
Mister 2's Avatar
^^^ what he said.
Old Aug 29, 2004 | 05:18 PM
MO REX's Avatar
I am worried about a possible leak. If it wont leak I'm going to knock the pieces off with a dremmel to make sure none of it gets into my turbo.
Old Aug 29, 2004 | 07:40 PM
Littleboyblue's Avatar
Have you tried taking it to an exhaust shop? They might be able to doing something if you are worried about it leaking.
Old Aug 29, 2004 | 08:29 PM
MO REX's Avatar
Im going to have Ron at Axis Power look at it some time this week. I need to stop by his shop to order my TXS DP anyway.
Old Nov 6, 2004 | 09:17 PM
MO REX's Avatar
I've had the pipe on for quite some time now and everything is a ok.
Thanks for the help
Old Nov 8, 2004 | 12:49 AM
Thats good!
Jbora
Apr 16, 2013 10:44 PM
thunder_sti
Oct 11, 2005 07:28 PM
esracer
Jan 19, 2004 11:35 AM
masterod
Aug 16, 2003 03:17 PM
