sti injectors???
Old Feb 20, 2004 | 12:14 AM
davisvans's Avatar
sti injectors???
planning on getting a set of sti injectors, do i need the sti fuel rail? and is the 04 usdm sti the one one in pink?
thanks
davis
Old Feb 20, 2004 | 12:18 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
If you're talking about for a WRX, no you do not need the STi rails, as long as you get the JDM STi pink top feed injectors (which is what EVERYONE just calls "STi injectors").
The 04 USDM STi injectors are side feed and incompatible with the WRX fuel setup.
Old Feb 20, 2004 | 12:23 AM
davisvans's Avatar
thanks mexicanpizza
Old Feb 20, 2004 | 12:26 AM
Anytime bro. You should check out www.mpjperformance.com in Hayward if you didn't know about them already. They rock, and have great prices.
Old Feb 20, 2004 | 10:32 AM
mr pizza if i get injectors and a pump would i need to retune b4 i put in teh trubo?
Old Feb 20, 2004 | 01:50 PM
ilivas's Avatar
go for the ultimate racing 600 cc injectors, they're a little cheaper than STi and the flow more than the STi 565 cc. I think that ultimate racing sells them for $405.
Old Feb 21, 2004 | 02:42 AM
Originally posted by crash n burn
I know you were asking Mr. Pizza this, but you should install your stuff before doing the tuning. Are you doing a dyno tune or just a reflash? If you go to a place and they just reflash it, a lot of the times, they can test drive your car just to make sure there isn't anything noticeable like pinging or things of that nature. If you are using standard stuff that is normally used (ie. IHI turbo, STi injectors, Walboro fuel pump), everthing should be fine. If you use different stuff, their baseline maps may not be 'exactly' what you want and you may want to have your car custom tuned. Mr. Pizza will now speak and probably put something in there for me to go do something with myself or something since I butted in.
thanks for the info live and learn crash and burn
so you say put the sti injectors in on the stock turbo and it will run fine ?
Old Feb 21, 2004 | 02:43 AM
where are they at on the internet?
Old Feb 21, 2004 | 02:55 AM
ilivas's Avatar
http://www.ultimate-racing.com/Products/Subaru-US.shtml
Old Feb 22, 2004 | 10:25 AM
im putting a turbo in but i cant afford it all at once so i can get some stuff then wait then more i think ill just buy the stuff and let it sit until i get everything
Old Feb 22, 2004 | 09:01 PM
verc's Avatar
Car Info: GT35R, Meth
one thing though, I don't think the stock ECU is compatitble with the bigger injectors, correct me if I'm wrong
Old Feb 22, 2004 | 10:09 PM
ilivas's Avatar
Sti, or any other after-narket injector you must have engine management.
supra_speed
May 28, 2010 12:08 AM
drifter04
Jun 13, 2008 10:27 AM
xitonedefix
Subaru OEM Parts For Sale
Feb 16, 2007 09:45 PM
fd3s/wrx
Jan 26, 2006 04:16 PM
subiedave
Aug 7, 2003 10:06 PM
