starting troubles in hot weather
Old Sep 4, 2007 | 10:25 PM
rustokman's Avatar
Car Info: Black 03 WRX
Ok, I've had this happen to me a few times before.
It's super hot (LA) and I drive around for a while, then I park my car for a while and when i come back it won't start, it just clicks. So what I do is I open my hood and let it cool down, and then it starts no problem.
I replaced the battery a few months ago because it wasn't holding a charge so I figured that was it (I have a voltmeter in my turbo timer) but today the batter was fine, and it happened again.
I figured it was something witht he starter overheating and the gears not working till it cooled down a bit so I was about to just replace the started with a newere one on ebay or whatever. Then I read this:
Engine won’t start when its hot
Problem: Engine won’t start when its hot.
Diagnosis: Possible fuel injection problem: Electornic Fuel Injection (EFI) system needs to be looked at by a mechanic. Could also be a problem with the cold start injector or Coolant Temp Sensor. Could also be a vapour lock or a problem with the injection module or EFI overheating
Solution: Need to call a mechanic for this, who will need to replace the parts. Alternatively you can open the hood and let the car cool down for a while then try again.
i got this on the site: http://www.caradvice.com.au/37/car-d...-doesnt-start/
I don't want to do exploratory surgery on the car for no reason, nor do I have the money for pointless repairs.
I'm probably going to finally seafoam the engine through the vacuum lines in a couple weeks, so that should clean my injectors.
Also, What is vapor lock?
Old Sep 7, 2007 | 12:08 PM
rustokman's Avatar
anyone?
fixmuflym
Dec 13, 2004 06:36 PM
WindingRoad
Aug 11, 2004 10:09 PM
Ditty77
Feb 4, 2004 03:41 PM
