Slow vf34 EJ205 ????
Old Oct 26, 2006 | 03:48 PM
phreak9i6's Avatar
my hard as hell to read yellow slip says 97mph
Old Oct 26, 2006 | 03:55 PM
skeeler's Avatar
Car Info: 05 WRX sedan
oh my bad it was up higher... Just go get the protune, you get the extra hp over a shelf map. you launch at 4500 and when do you shift gears?
I launch at 5500
Shift to 2nd at 7000
Shift to 3rd at 7000
Bounce off rev limiter
= 14.1 or better, down to my 13.7 best.
I've seen some kid with a red WRX and he had the same mods as you except he said he had the japanese WRX turbo? His best was mid 14s. Sounds like you guys could have the same problem lol
Old Oct 26, 2006 | 09:03 PM
phreak9i6's Avatar
I met that guy with the red wrx. I doint think he had the upgraded turbo though. Just a JDM WRX motor.
Anyhow I would launch at 4500, and shift at redline each gear.
Old Oct 29, 2006 | 10:56 PM
chri5's Avatar
Car Info: 02 wrx
Originally Posted by skeeler
I launch at 5500
Same here. With the bigger turbo (I just called a vf a bigger turbo lol) you have to be up in the 5-5.5k range. The td04 was fine to launch at 4.5k, but with the vf I tend to bog a little when launching there.
60' - 2.0
13.831@ 97.77
This was with...
vf39@17psi
TXS TMIC
Cobb DP
UTEC
sti injectors
APS turbo inlet
Stock cat-back (I'm lazy )
stock uppipe (I'm lazy. Notice a trend? )
Old Oct 30, 2006 | 04:11 PM
skeeler's Avatar
weird, im thinkin with a vf39 turbo, you guys would be trapping more than 97 mph. Im confused as why I am trapping higher (99)? Could someone explain to me?
Old Nov 3, 2006 | 07:13 PM
chri5's Avatar
Car Info: 02 wrx
for me...stock uppipe, stock catback, low boost.
Old Nov 6, 2006 | 06:23 PM
wrxguy's Avatar
Car Info: 04wrx
i ahve the same setup.. the vf34 and i ran a 13.3 at infineon... just try launching higher and shifting faster i guess
Old Nov 7, 2006 | 08:24 AM
yanwasp's Avatar
Car Info: WRX
not to put you down but I definately think it is your mad skillz. you may need to slip the clutch more so that it does NOT bog. getting a custom tune will not help much if you don't have the skill to take advantage of it. That bog is costing you at least .5 sec. keep practicing. try launching at different RPM and varying the amount of slip to suit your style.
Old Nov 7, 2006 | 09:13 AM
skeeler's Avatar
just go to a road where nobody ever goes, and practice a lot until you find out what works for you.
LAGSBOXER12
Jun 28, 2005 11:15 AM
REDI-wgn
Jul 18, 2003 11:13 AM
REDI-wgn
Jun 28, 2003 10:08 AM
wackie
Wanted
Mar 15, 2003 08:57 AM
azscoobie
Mar 13, 2003 06:46 PM
