Slow vf34 EJ205 ????
Old Oct 25, 2006 | 08:31 PM
phreak9i6's Avatar
I recent brought my 03 wrx to the drag strip to see what she would run.
I'm running cobb stage 4 map,one step colder plugs, helix tmic, vf34 turbo, sti injectors, walbro pump, 3" turbo back (4" belmouth dp) uppipe. Completely catless. I can only seem to get around 14.3... this number is disappointing and I'm begining to expect something might be wrong.
I do seem to get decent boost in all gears (16 +/- .5) as per the map says. I'm not sure waht else to check. Any suggestions? Is it just my crappy driving? I seem to bog down on launch (~4500 rpm with some feathering)
Old Oct 25, 2006 | 08:54 PM
cbf246's Avatar
Car Info: 04 WRX
are you running the AP stage 4 map? or a custom stage 4 tune? 14s are really slow for what your running.
Old Oct 25, 2006 | 09:56 PM
Superglue WRX's Avatar
14.3 sec = stock EJ205 w/ good driver
I think it's a combination of your drag skills and the OTS map. It sounds like that map isn't working for you at all. Get your car to a respectable tuner and have him tune it on a few dyno runs, I'm betting that will clear everything up.
Or, in retrospect, a lot can be associated with your location. Desert heat and mountainous areas tend to kill performance also.
Old Oct 25, 2006 | 10:20 PM
im going to sound like a dick but oh well
the problem is between the steering wheel and the seat
whats your 60 feet time
but for reals where are you running?
if you are in denver then your fine
Old Oct 25, 2006 | 10:46 PM
wagonrex's Avatar
I have almost the same setup as you but I have a JDM STI TMIC and some other stuff. Before I got the tune last weekend, my boost spike and the car doesn't drive smooth at all. I didn't hit target boost with the off the self map.
got the tune the car drives much better now and I hide 19lbs and no spikes.
Old Oct 25, 2006 | 10:50 PM
subie OCD's Avatar
Car Info: 04 STi
WHats the trap speed?
Old Oct 26, 2006 | 08:34 AM
phreak9i6's Avatar
Dont worry about sounding like a dick its okay. I know taht I'm part of the issue, I'd rather hear that then to hear that its the car.
So I am running the OTS Cobb map. my 60ft is like 2.3 (not great I hear). my trap speed was 97mph
I seem to bog down when I launch, then it pulls real strong
I'm not really interested in drag racing, but I was hoping to get a good idea of mine and the car's ability.
I submitted a request to PDXTuning to get a new map with the hopes that they might be able to help vs going to a tuner. I've been thinking about gettting an appointment locally though with dbtuned.
Old Oct 26, 2006 | 09:10 AM
where did you run?
if its bogging you arent slipping it enough
Old Oct 26, 2006 | 09:33 AM
phreak9i6's Avatar
sacramento speedway
Old Oct 26, 2006 | 09:44 AM
wagonrex's Avatar
different car reacts differently to the OTS map or other non-custom map. A protune will bascially give you a map that is taylored to your car. From what you are saying it seems like your car is not running smooth at all if you can only feel it kick it after u lanuch for a while. Of course the turbo doesn't kick in at low RPMs but then it shoudl be smooth and not jerky. Trust me get a protune. It's so worth it. In my opinion, if you are stage 2 or below, you won't see a differences with the protune, but since you are on stage 2.5 w/ a non-stock turbo then get a protune because drivability while getting power is very important IMO.
Old Oct 26, 2006 | 10:30 AM
Originally Posted by phreak9i6
sacramento speedway
im not familiar with that track sorry
does it usually run slow?
ask the other people that go there alot if its a slow track or not
it could be that too
Old Oct 26, 2006 | 01:13 PM
phreak9i6's Avatar
well in comparision. my friend's stock STI ran a good 13.6
Old Oct 26, 2006 | 02:42 PM
skeeler's Avatar
Car Info: 05 WRX sedan
I ran 13.7 @ 99 on my wrx. i have an UP and TBE with protune. I'd say its your driving man. I race at sac raceway also and people pull decent times there. You should get a protune. 195 awhp @ 6300. 180 tq. You driving that red WRX, i think ive talked to you b4 if you have a red one
Old Oct 26, 2006 | 02:47 PM
phreak9i6's Avatar
yea I should run way better. I wouldn't doubt that its my driving, just worried it might be something else. =\ I was having some boost leak issues with a GFB BOV, I swapped on the stocker. I'm also using a nitrous IC sprayer.
I have the blue wrx with the CF hood and gold rota torques.
Old Oct 26, 2006 | 03:02 PM
skeeler's Avatar
whats ur trap speed?
