Serious Engine Overheating cannot explain
Old Jan 11, 2020 | 11:30 AM
knightsnke's Avatar
Car Info: 2003 WRX
Hello. I have been a member since 2003. I still own a 2003 wrx. I had 214,000 miles on the engine and the head gasket blew. I am working with a mechanic that got me a used engine for $1000.00 with around 98k on it.
It was running superb but within a week i noticed much white smoke and then massive overheating. I brought it back and it turns out that the Head Gasket was BAD. He is trying to bill me for the repairs which I am disputing. I already
contacted consumer affairs and told them once the car is fixed I will file all complaints that I can. Today 1/11/20 after having the car over a month it is still overheating. He changed the timing belt, water pump, thermostat, head gaskets, and radiator.
HE believes it is a cracked engine block. I'm without a paddle for close to 2 months now. He tried running it without a thermostat and it still was over heating. Does anyone have any other ideas as to why it can be overheating.??? thank you for your time.
KEN
Old Jan 11, 2020 | 06:56 PM
CHESTON's Avatar
Car Info: AW Pig-STI
Oof, sorry to hear that man.
overheating causes that i can think of:
* leaking head gasket
* extreme off timing (e.g. skipped a tooth on timing belt, or loose/bad/failing timing belt tensioner -- use OEM tensioner)
* unsuccessful purge of coolant system (FYI, the EJ coolant system is tricky as hell to purge properly...not surprising if takes AT LEAST a couple of heat cycles to purge correctly [yes cool it off to ambient] and have the front of the engine/the Upper Turbo coolant reservoir (the one sitting above the turbo, not the one at front of engine bay) as the HIGHEST point during the purge cycles)
- see Lisle Air Funnel for recommended burping tool for Subaru Coolant system
- also hope the heater lever was on full HOT during the burping process
- to check this...does your heater work and stay working full hot when you put it to 'hot'...as in does it stay hot and not have spells of cold air blowing?
* bad/failing water pump (did you use OEM, as in SUBARU water pump, i personally do not recommend aftermarket standard ones like GATES, etc.)
* bad/failing Radiator cap. note that Subaru's have two caps, but if you're having problems here, make sure that BOTH caps are OEM (e.g. no hi-pressure caps) and fresh from dealer.
* clogged radiator
* cracked block
These are some thoughts, and i hope you acheive a cheaper solution to your overheating problem. Good Luck!
X-VWGLX
Jul 2, 2005 08:34 PM
overdose
Mar 17, 2004 11:56 AM
cazbert
Jan 16, 2004 06:48 PM
