scoobysport 2.5" or 3"
Old Apr 25, 2005 | 10:52 PM
lugee's Avatar
Car Info: o4 PSM WRX
Just a simple question on the difference.
I was reading through the rallyperformance website and they said that they can make a 3" if i need it.
i am planning to upgrade to a vf34 in the future and was wondering if it was smart to go for the 3" exhaust. but then again im debating between the stock turbo and the vf34.
also, is the scoobysport even legal?
thanks.
Old Apr 26, 2005 | 03:49 AM
Wingless Wonder's Avatar
3" tubing is better for any turbo upgrade over stock.
In CA, only catback exhaust systems are emissions legal. Technically, all three factory catalytic converters must remain in place except for off-road use, only. Replacement high-flow cats are sold with a variety of exhaust systems but can only legally be used if your car meets certain criteria (OEM cat failed, odometer reading at time of failure, etc.).
You can use any exhaust system you choose but be prepared to remove it all and replace it with factory stuff when smog check time finally rolls around.
streko
Wanted
Sep 21, 2006 09:44 AM
bcinlas4
Apr 29, 2005 02:54 PM
pakumi
Feb 20, 2005 09:29 PM
Hyper
Sep 16, 2004 05:26 AM
Pat L.I.
Dec 19, 2002 05:14 AM
