Samco hoses... Are they REALLY worth it?
Old Oct 9, 2003 | 11:04 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
if you just put on the hoses and don't reset the ECU, guess what? your computer is still on the maps that it has been fine tuning since you last reset your ECU. do you think it's going to be optimized whatsoever for the new hoses you just got? DUHHHHH!!!!
when you put on the hoses, follow the proper ECU reset procedure, and immediately do a few pulls from 2K to 7K in third gear. if you don't notice a difference, you've got problems. the hoses are definitely a good mod, and are definitely noticable as a first or second mod. why do you think vishnu among others have maps for uppipe and ic hoses?!?! do you think they might have tested a few bolt ons before they settled on those two?
and for the guy complaining about how he can't use the stock clamps, are you serious? have you ever seen what a hose clamp looks like? you can buy them at any hardware store, let alone auto parts store. for the record, the ic hoses make it much easier to remove and replace your ic if you need to do it for any reason.
Old Oct 9, 2003 | 11:56 PM
DarriiffftaaHuy's Avatar
Actually... my only complaint is that these are HARDER to remove and replace than the stock hoses... yes, you heard me right... the stock hose has a little tab on it so you can push it back on the turbo with a simple screw driver.
I did not reset the ECU and immediately noticed a difference in power... it just got better over time.
Old Oct 11, 2003 | 01:01 PM
REDI-wgn's Avatar
Car Info: '03 Wrx Wagon
what is the proper reset procedure,
is there a back-up fuse like on the hondas or is it just disconnect the battery??
ps .. mine get in on monday (HOPEFULLY), see they will be on the car by saturday afternoon.. will update
Old Oct 14, 2003 | 01:15 AM
Azjon's Avatar
Car Info: 2003 WRX Metallic Silver
I'm going to be ordering mine next week. Anyone know the best place to get them?
Old Oct 14, 2003 | 01:36 AM
sub-sonic's Avatar
i installed a samco ic hose- noticed the difference right away. I'm a believer- get one its worth it.
Old Oct 19, 2003 | 11:51 AM
REDI-wgn's Avatar
mine are in...
noticed difference.....
nuff said.
Old Oct 20, 2003 | 02:45 PM
serrano's Avatar
Originally posted by BAN SUVS
Most people with hoses are happy with them. They typically dyno at 5-7 whp gains.
Is this just with the IC kit? Or with the full radiator/IC/9 piece hose kit?
Old Oct 21, 2003 | 06:05 AM
ride5000's Avatar
the radiator and ancilliary hoses don't add any power.
ken
Old Oct 21, 2003 | 06:57 AM
REDI-wgn's Avatar
does the intake hose add any power gains also ??
Old Oct 24, 2003 | 12:54 AM
Daredevil's Avatar
yea
im sold, where can i buy?
and what exactly do i want for the power
when people say the intercooler hoses how many is that? 3? and waht is each one called
thanks
Old Oct 24, 2003 | 01:19 AM
ScoobyBoy's Avatar
mpj has them for 120 shipped. ive got them and i honestly didnt notice anything. maybe smoother boosting but thats about it. and the turbo sounds a bit more silenced.
Old Oct 24, 2003 | 10:37 AM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
i have the perrin ic hoses
The car runs smoother, but it'll run alot smoother with a full turboback too.
I got road dynoed with turboback exhaust (helix dp&bosal catback)and the perrin hoses at:
Maximum Wheel Power: 188.8 BHP @ 5941 RPM
Maximum Wheel Torque: 187.2 LbFt @ 4121 RPM
i also have the STi Scoop+GT-Spec splitter, and the Smonkee grounding kit. the grounding kit seems to smoothen stuff out but then again it could have been the ecu reset. I also had the 3/16th mod when i did that run. At first the 3/16th mod is great, boost response seems better and quicker. After a while i noticed my boost would fluctaute and not hold solid and then taper like it's supposed to, so i took it off. My ecu is currently at Cobb for the stage2 reflash.
