Safe to run vf30 on stock boost control?
Old Mar 2, 2003 | 08:04 PM
WREXXED's Avatar
Car Info: 2002 WRX
I am waiting on my injectors to arrive and seding my unichip back to TXS to have the stg4 map loaded. So I was wondering if it would be safe to install my vf30 and use the stock boost control until I get my injectors installed and unichip back from TXS? I already have the fuel pump in.
I've heard it's okay to run a vf30 on stock ecu and fuel as long as you keep the boost down, but what if I am using the stock boost controller and can't lower the boost?
Old Mar 3, 2003 | 07:44 AM
jrauck's Avatar
Car Info: Sil. WRX
i ran a vf30 on stock boost levels for a while (3 months) until i got my injectors and chip in too, so you shouldn't have a problem. Go for it and enjoy the extra power until you get your injectors and chip back.
Old Mar 3, 2003 | 01:30 PM
WREXXED's Avatar
Car Info: 2002 WRX
cool, thanks. Were you still getting 13-14psi or did your boost change because of the turbo?
Old Mar 3, 2003 | 06:38 PM
jrauck's Avatar
Car Info: Sil. WRX
it'll run the factory boost.......it'll take a little driving for the factory ecu to adjust to the added flow and then you'll get the extra hp
projectwrx
Jan 19, 2006 05:56 PM
Astacun1
Jun 28, 2003 03:12 PM
WRXshagnWGN
Mar 31, 2003 02:25 PM
K2Skier
Feb 17, 2003 05:47 PM
spdkills
Jan 8, 2003 01:25 PM
