Rich mixtures and MAF sensor
Old Apr 1, 2004 | 02:27 PM
Mister 2's Avatar
how do you know it is running rich? what are you using to monitor a/f ratios and how rich is it?
Old Apr 1, 2004 | 05:11 PM
do you have a cai or bov?
Old Apr 2, 2004 | 05:23 AM
wolfen42's Avatar
Unhappy
Are the BOV and CAI your only mods?
Old Apr 2, 2004 | 08:40 AM
wolfen42's Avatar
Post
Actually from the reading I've done... Your car sounds like a car with a turboback exhaust that hasn't been tuned.
Are you completely catless after the turbo?
Old Apr 3, 2004 | 09:11 AM
Originally posted by ride5000
clean the maf.
brake cleaner, in a bag, with the maf, shake it around.
jm2c
ken
From another thread found here:
https://www.i-club.com/forums/showth...ight=clean+maf
Originally posted by amnzamudio
I dont have an AFC or anything, so there are no actual numbers telling me if I am running rich or not. I do have a BOV and an HKS Power intake installed (mushroom shaped foam filter one). The exhaust just smells really "gassy", and when I stomp the pedal, the engine seems to get choked out, almost like a hesitation. Changing plugs helped it a bit, and I dont run crappy gas, so I dont have any idea what it is. I just noticed there was a nice oily buildup on the inside of my intake near the MAF sensor. Thought that might be the problem.
First try going back to the stock intake and bypass valve. Use copper plugs one range colder than stock. The part number in the owner's manual for NGK coppers is off by one heat range for modded cars.
Old Apr 3, 2004 | 10:55 PM
RussB's Avatar
Car Info: $200,000 sports car
try electrical contact cleaner.
verc
May 14, 2009 08:10 PM
dan avoN7
Dec 19, 2006 09:46 AM
WindingRoad
May 24, 2005 10:22 PM
BluWrX.03
May 7, 2003 11:33 AM
