Reversed Intake Manifold
Old Jul 4, 2005 | 12:10 PM
9Vapors's Avatar
Car Info: 02 WRX
What is the purpose of the reversed intake manifold? Does it provide any power improvements? Convenience for custom intercoolers? I have seen several of these mods, even on Imprezer's car. (Stole your pic for reference Alex, hope ya don't mind)
-John
Old Jul 4, 2005 | 12:26 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
The purpose is:
1. Shorter ic piping
2. less bends in piping (mine is done on the after IC side, pre IC side still under construction)
3. Creates more room in the engine bay.
4. Ultimate pimp factor...
Old Jul 4, 2005 | 08:33 PM
Dice's Avatar
Car Info: 2002 WRB WRX
whats needed to do the mod?
Old Jul 4, 2005 | 08:41 PM
9Vapors's Avatar
Car Info: 02 WRX
Indeed, the Pimp Factor is high!
Old Jul 4, 2005 | 08:49 PM
Imprezer's Avatar
Admin v2.0
Mechanically, it bolts right on. You cannot use stock fuel rails and the harness needs to be flipped and some connectors extended. I also removed AC, but you could keep it and have the pipe loop over it. Not as pimp as without AC. I had to remove mine, because I am running a huge 75mm Edelbrock throttle body.
Old Jul 4, 2005 | 10:56 PM
Dice's Avatar
ooo so u can basically just turn it around with some minor fabrications? in that case its pretty cool and i guess with custom intercooler piping for a front mount it would decrease turbo lag right? im thinking of gettin the vf34 setup with an injen fmic because its smaller than other front mounts. what do u think alex, any pros n cons that you know of with this intercooler? p.s. sorry if i just hijacked the thread with that question.
Old Jul 7, 2005 | 10:56 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
so what would labor charge be on work like that?
Old Jan 10, 2006 | 10:55 PM
how long did this take?
Old Jan 10, 2006 | 10:59 PM
Imprezer's Avatar
Admin v2.0
How long did what take?
Old Jan 11, 2006 | 10:22 AM
from start to end
flipping the manifold?
HEKTIC
Sep 26, 2006 07:27 AM
Renick Motorsports
Engine and Drivetrain
Sep 23, 2006 11:29 PM
Chibby Goku
Jan 10, 2006 10:40 PM
Subaruski42o
Jul 15, 2003 07:36 AM
