Removing Tumble Valve Generators?
Old Sep 25, 2003 | 12:13 AM
SJwrx's Avatar
Car Info: STi Motor Mounts, Synthetic Fluids, nothing else yet
Hello everyone,
I am just wondering what people's opinions are on remvoing the TVG's... on a personal or experience level.
The two roughts are going with the stockers and using epoxy to fill in the holes and smooth everything out...
...or...
Buying STi replacement sections that don't incorporate the TVG, and have an edged section within the section...
Now thats all well and good, but what about the effects on the ECU, running conditions, cold starts, and what not.
What should this modification include (ECU upgrade, custom wiring, etc. ) ?
Rich
Old Sep 25, 2003 | 01:33 PM
Personally I would just get the STi manifold. Of course, if you do that, also try removing the TGVs just to see if it works. That way you can put the STi mani on when/if it doesn't.
Old Sep 26, 2003 | 07:02 AM
DeliciouSpeed's Avatar
Good mod for sure, the stock ECU will not be happy though.
Old Sep 26, 2003 | 06:37 PM
SJwrx's Avatar
Any curing it of that will require?
Rich
Old Sep 26, 2003 | 06:46 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
I took mine out, welded the holes and had them ported. That was before the STi's were available all over the place.
I think it is not worth it hacking your stock ones. Just get the STi's. And, there is no need to get the whole manifold. Just get the TGV housings.
- Alex
Old Sep 26, 2003 | 09:40 PM
Group B's Avatar
Dahveed aka Robin Hood
ECU reflash & tune would do it....
Rich
Old Sep 27, 2003 | 02:50 AM
SJwrx's Avatar
That's it? Thought it'd take a lot more that...great!
Rich
Old Sep 27, 2003 | 08:41 AM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
personal experience with the tgvs removed: trouble with cold starts. STi manifold is a lot nicer. Cold start issue went away after Autronic was installed for other reasons.
Old Sep 27, 2003 | 04:41 PM
SJwrx's Avatar
Isn't the STi manifold the stock WRX peice, just painted?
Whats Autronic? Is it stock Subaru?
Rich
Old Sep 28, 2003 | 08:45 AM
Jgrahn555's Avatar
Sarcastic Jackass
No, an aftermarket ECU, and no.
the autronic was used primarily for other reasons, but it helped out with this TGV situation.
Old Sep 29, 2003 | 07:03 AM
It's all in the tuning. The manifolds are the same.
austinp02
Hawaii Classifieds
Aug 25, 2007 04:46 PM
wonton2049
Jun 8, 2004 04:45 PM
AWDrifter21
Mar 4, 2004 06:43 PM
AWDrifter21
Mar 2, 2004 08:20 PM
pacobeagle
Subaru OEM Parts For Sale
Jun 30, 2003 08:10 PM
