random tech. mid-pipe w/high flow cat...
Old Dec 16, 2003 | 03:54 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
http://www.3sxperformance.com/wrx/exhaust.asp
-- it's down at the bottom of the page. anyway, has anyone used one of these to build your own turboback? it would seem to me that you could do sort of a staged approach to it; i.e. up/down pipe, then a cat back later, and then the midpipe, resulting in a high flowing turbo back. obviously you'd have to have DP that works with the stock center cat, but other than that you'd only really be limited by your imagination...
Old Dec 16, 2003 | 08:42 PM
Wingless Wonder's Avatar
I looked at Random Technology's WRX page for quite a while. I like their approach to making clean-running engine parts and I like the fact that they use 3" tubing, but I haven't seen a good photo of their downpipe turbo flange. I would like to know if it's a bellmouth or just a typical flat plate flange.
Strömung has just come out with a 3" turbo back system, using a divorced wastegate downpipe (no cat available), high-flow third cat pipe, and their current 3" catback. I think their components are supposed to bolt up to factory WRX stuff, too.
Old Dec 16, 2003 | 09:52 PM
the link that i posted has the best pics i've seen yet of their products. i'm 99% sure that their DP isn't a bellmout, and i'm 100% sure that its not a divorced wastegate design . i was thinking that the midpipe w/cat would be great for replacing the WRX's 3rd cat for those running it with and up/downpipe combo. it looks to me like it should bolt right up to the stock pieces.
Old Dec 16, 2003 | 10:34 PM
The Mirror's Avatar
Interesting. I wasn't aware that anyone offered a high flow uppipe with a cat.
Old Dec 17, 2003 | 05:50 PM
drwrx's Avatar
I have talked to Random technologies about their mid pipe, and it WILL NOT mate-up with the stock unit (or the bosal dp or Scooby Sport dp). The stock flange off the dp is a 2 3/4" oval, the Random tech is a 3" round. If you are trying to find a high flow 3" midpipe w/ cat to match-up to your stock/bosal/scooby sport dp you are SOL. However, a good machine shop can make you a 2 3/4" oval flange cheap and an exhaust house should be able to custom build you a center pipe for about $100.00. You can pick-up a high flow cat for around $70 at any number of sites. That is the only solution I know of.
Old Dec 17, 2003 | 09:20 PM
damn, that sucks. thats a hell of a lot of work to make a high flow cat fit.
FLT/4/PWR
Sep 9, 2010 09:47 PM
SubyRS25
Mar 17, 2008 05:55 PM
DaFastOne
May 4, 2006 01:40 PM
Chrisnonstop
Jan 22, 2004 06:25 PM
Ninosautoacc
Vendor Group Buys/Specials
Jan 16, 2003 07:38 PM
