Questions..HELP!!
Old Jan 2, 2003 | 08:38 PM
stealth-wrx's Avatar
it is much easier to change oil when it is warm/hot because the oil is thinner and flows faster. usually i disconnect my negative terminal. so why do you think you need to change your oil right now?
Old Jan 3, 2003 | 01:54 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
The oil is thinner when hotter.
The "W" rating is just a different scale. It doesn't stand for "weight" it stands for WINTER.
A SAE30 oil takes 58-70 seconds to fill the flask at 210F,
an SAE40 oil takes 70-85 seconds, and
an SAE50 oil takes 85-110 seconds.
There is also a test for low-temperature viscosity that is designated by a "W" suffix on the SAE viscosity rating.
A SAE5W oil takes less than 6000 seconds to fill the flask at 0F.
An SAE10W oil takes 6000-12000 seconds, and
an SAE20W takes 12000-48000 seconds.
Look here:
http://www.type2.com/library/mainten/oilw.htm
That being said I like to change oil when it's warm also.
__________________
GO24JUNIOR
Nov 7, 2003 01:05 AM
O 16581 72452 5
Sep 18, 2003 09:37 PM
View Askew
Jul 16, 2003 12:03 PM
tom@jt
Dec 4, 2002 07:10 PM
