Questions about Dual stage boost controllers
Old Jan 24, 2004 | 04:01 PM
mario's Avatar
I had the Dual stage boost controller It was useless for me. Ask yourself this do you really need a dual stage boost controller?? Do you really need a switch in the cabin that allows you to switch from 12 psi to 16psi or any other set of boost you desire?? You would still have to go into the engine bay to set the desired boost. Let me tell you what i think the dual Stage BC was designed for. I think it was designed for a rear or front wheel drive car, at a launch they could set a low boost so they would no lose traction, then after switching to the next gear were they feel they have more traction they switch to the 2nd stage of boost (which is ususally higher) for more power. You see what im saying?? You could save up another another 2 or 300 bucks and get a EBC which you will really benifit from, and then you can set your boost from inside your car, if that what matters to you. Good luck
Old Jan 25, 2004 | 01:04 PM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
The factory boost solenoid regulates the opening of the wastegate and is not a pressure sensor that helps control afr. If you look at where the tubes for the factory solenoid come from off of the turbo outlet and the intake system
The pressure sensor that does control the afr and senses boost is located on the throttle body so that it has an accurate measure of what the manifold pressure really is.
You will recieve a cel if you don't connect it properly but if it is all done right you should be in the clear. The only other problem is the partial throttle full boost issue but since this isn't a daily driver I doubt you will be plauged with this issue.
-skooter
Yin
Jan 19, 2007 04:57 AM
mario
Jun 1, 2003 08:27 PM
v1rus67
Apr 21, 2003 06:17 AM
v1rus67
Mar 19, 2003 12:48 PM
XwrxX
Dec 17, 2002 07:14 AM
