Question on version 8 STI engine parts
Old Jan 22, 2008 | 02:37 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
We are looking for parts to complete a version 8 sti swap in a 2.5 rs. We have a near complete motor, but it is missing the intake manifold, injectors, maf, wiring harness, alternator, and coolant reservoir.
Question is are any of these parts the same as on US model engines like the WRX ej20 or STI ej25?
Old Jan 28, 2008 | 07:57 AM
testes1010's Avatar
I would think the MAF, coolant reservoir & the Alternator maybe swapable from either a USDM STi or USDM WRX. The v8 STi intake manifold is TGV-less, all USDM models have TGVs. You can order a new v8 intake manifold from Rallispec. The v8 sti injectors 'pinks' are different as well from all the USDM ones, ALTHOUGH the 2006-2007 WRX will swap easily with only minor changes to the ECU needed to run optimal. The v8 wiring harness has the AVCS wiring so you'll have to have a v8 harness. Check with Rallispec or IAPerformance.
Old Feb 1, 2008 | 09:53 AM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
i don't know if he said it, but you'll have to mod your fuel rails for a v8 to fit in something not a v8...other than that^^^^^^well said.
Old Feb 1, 2008 | 09:54 AM
are you running STi head or WRX head...because the 2.0 can hold a higher amount of compression.
charlesj
Wanted
Jan 22, 2008 02:34 PM
big dawg
Aug 1, 2006 07:12 PM
Bob 53
Nov 21, 2005 10:35 AM
Billy
Wanted
Apr 3, 2003 08:22 AM
