Question on Crank pulley install
Old Sep 21, 2004 | 10:27 AM
greddy5's Avatar
Car Info: 04 WRX
I was reading the Vishnu Performance Stage Zero install instructions and had a question regarding part 1 of the install (underdrive pulley). Do you really need to jack the car up and put it on jack stand if you are just doing the pulley remove and install? I have to help a friend remove his Perrin Crank Pulley and just wanted to make sure we do it right. He is going back to stock and trading his 02 WRX. Any info will be much appericated.
Old Sep 22, 2004 | 07:08 AM
ride5000's Avatar
no.
Old Sep 22, 2004 | 09:52 AM
greddy5's Avatar
Car Info: 04 WRX
Thanks for the reply....
Old Sep 27, 2004 | 07:39 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
No jack stands are not required. Get a 3 foot long breaker bar to break loose the nut 17 mm i believe. Then from there take it off and put it back on with the key hole in the right spot. Then once you have it on torque it to the required, 85lbs i believe. Not for sure on that though. Good Luck and dont break the radiator hose doing it.
Rush
Old Sep 27, 2004 | 08:35 PM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
You don't have to jack the car up. Actually it is a 22mm deep socket and you have to crank it up to 96lb.ft of torque. How do I know? I just did it this weekend.
Old Sep 27, 2004 | 08:56 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
The only reason you would need a jackstand, is if the pulley bolt is seased and you would want to throw the jackstand at it in anger.
Old Sep 27, 2004 | 10:37 PM
greddy5's Avatar
Car Info: 04 WRX
LOL...its kool...I have done 2 crank pulley's since i started this thread....The install was so much easier the second time around lol.
Old Sep 28, 2004 | 08:55 AM
LOL!!! anyways this thread will be helpful for those who search ....
Old Sep 28, 2004 | 01:10 PM
LucidTrancer's Avatar
Car Info: 2004 Java Black Pearl Wrx
Help me install mine!!
Hahah hey.. someone willing help install my crank pulley correctly? I live in orange county. Oh yeah...and my shifter bushings too... I'll give u 40 bux..lol
demonbugeye
Hawaii Classifieds
May 4, 2009 03:26 AM
Speed Element
Mar 30, 2006 10:39 AM
Speed Element
Dec 25, 2005 10:08 PM
