Question about coolant draining
Old Sep 26, 2008 | 09:31 PM
VRT MBasile's Avatar
When I loosen the petcock, is the coolant going to come out of the hole on the side or the hole on the bottom?
Old Sep 27, 2008 | 10:46 AM
now that (almost) everyones awake.....who wants to give it a shot at answering?
Old Sep 27, 2008 | 10:57 AM
subie OCD's Avatar
Car Info: 04 STi
All I can remember is that its slightly messy - and make sure you let the car cool down for at least an hour, its freakin hot!!
Old Sep 27, 2008 | 11:35 AM
03_Impreza_Al's Avatar
Too much work going that route. Just remove the bottom radiator hose from the block let it drain and flush with distilled water.
Old Sep 27, 2008 | 12:00 PM
the thing is, I only have to drain enough so the upper hose is empty so I can replace it because it is leaking. LIC is changing the coolant (flushing too?) in a couple thousand miles.
Old Sep 29, 2008 | 10:16 AM
side i think i forget ill check when i get home
Old Sep 29, 2008 | 10:57 AM
forgot about this thread. It comes out of where the plug is, not sure of the point of the two other tubes on there.
FW Motorsports
Jul 20, 2009 05:36 PM
FullTilt
Mar 25, 2008 07:52 AM
UK n00b
Feb 8, 2005 09:10 AM
WindCloud
Aug 5, 2004 01:08 AM
Daredevil
Oct 5, 2003 01:39 PM
