put in downpipe, now problems help!!!! please!!!!
Old Aug 24, 2005 | 10:13 PM
1andONLYredREX's Avatar
Car Info: 2002 wrx
i just put in an invidia downpipe (02' wrx) and i have a straight midpipe and a blitz axleback. when i put it in when i go over bumps, and accelerate at different points there is a violet rattle\vibration coming from under the back of the driver's seat. is this normal due to the power increase? is the exhaust moving? it sounds like its rattling and hitting something, havnt had a chance to diagnose but does anyone know what the problem could be or i am freaking out about nothing? any help at all would be very appreciated thank you. PLEASE HELP!!!
Old Aug 24, 2005 | 10:32 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
It is most likely hitting a heat shield. just jack up your car and shake the piping as hard as you can to see if it hitting anything.
Old Aug 24, 2005 | 10:36 PM
slvrsubywgn's Avatar
^^Yeah what he said.^^ You most likely just need to reposition a pipe and/or tighten something up. Hopefully it's not rattling on your tranny cross member like my downpipe did.
Old Aug 25, 2005 | 09:56 PM
Car Info: 2002 wrx
what if it is rattling on the tranny corss member? will any damage occur??, if so can a simple heat wrap fix the problem of the rattling?
Old Aug 26, 2005 | 12:26 AM
jwrx's Avatar
Car Info: 04 WRX Sedan
you could use a piece of silicon tubing or get a universal rubber strap exhaust hanger.
Old Aug 26, 2005 | 12:33 AM
No serious damage should occur with the rattling, it's just annoying. I've got a different brand dp...I've never heard of this happening with the Invidia. A heat wrap could do the trick if you wrap it good...that's actually what I'm trying next because my modified hanger isn't working as it should. Or try the silicon, although I don't know how that would work.
Old Aug 26, 2005 | 06:37 AM
norcalridin's Avatar
Car Info: 2002 WRB WRX
check to see if its rattling on your driveshaft, i have an hks downpipe on my 02 and it rubs on the driveshaft when im decelerating, or having a ruff start, no damage to either parts, just some scratches, but its effin annoying...
Old Aug 26, 2005 | 08:44 AM
hockeygod's Avatar
Car Info: 2004 WRB WRX
When i first put in my Invidia TBE I noticed some rattling so I bought hardned polyurethane bushings and that did the trick for me. I drive hard on backroads from time to time and I experienced no problems to date. They are a pita to install though. I think 4 bushings with a friend took me 30 minutes to change.
Old Aug 26, 2005 | 10:12 PM
Car Info: 2002 wrx
thanks guys ill try all that stuff, soon, its starting to drive me up the wall
Old Aug 26, 2005 | 11:29 PM
rebbaz's Avatar
Car Info: civic
id be willing to bet that its the same thing that my 2 buddies had/have. the one that had it fixed it with 1 longer exhaust hanger in that location which replaces the stock one. my other buddy has yet to do it, but it rattles in the exact same spot. good luck.
Old Aug 27, 2005 | 09:55 AM
AzN121184's Avatar
Car Info: civic
check to see if there's any hangers that sit real close to other parts of the car i.e. axles, heatshields, sway bar.
Old Aug 27, 2005 | 07:17 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
mine rattles too i have helix DP and borla hush my piping hits the bolt onthe side of the diff when the exhaust shakes around. it hink if i put long exhaust hangers it should do the trick.
Old Aug 28, 2005 | 02:21 AM
taerron's Avatar
i had a similar problem. it was the exhaust itself hitting the floor board right behind the straight pipe hanger. i tried to move it away and it hit the rear diff. i was given a different exhaust cause no one knew what was wrong or how to fix it. stranger things have happened. i even had an endlink that would turn towards the inside of the car. weird........
stubz203
Mar 19, 2007 07:31 PM
grex767
May 27, 2006 10:37 AM
cruzinWRX
Jan 15, 2005 11:00 PM
mario
20
May 13, 2004 08:35 PM
hansolo
Nov 7, 2003 09:48 PM
