are properly designed headers good for power across the usable RPM band?
Old Aug 12, 2005 | 05:55 PM
Lowball's Avatar
Car Info: 02Wag on 17's
Originally Posted by nKoan
Alex certainly isn't disagreeing with me, I said "-ish," not "exactly".
I've heard some equal length headers that sound great (Cobb, IIRC) and some that I don't like at all. Maybe not Honda-ish, but certainly not as good as the stock headers, at least in my opinion.
What about the Grouppe-s headers, any idea how they sound??? And aren’t the headers, properly tuned, good for more hp and torque throughout the power band???
Old Aug 12, 2005 | 06:02 PM
Nick Koan's Avatar
Car Info: Legacy GT
I haven't heard them personally, but I hear they should sound very similar to Cusco's equal length headers (which I also haven't heard, but are supposedly amazing).
Old Aug 12, 2005 | 07:59 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
Yes, this is true....headers coupled with a good tune, and a good turbo back will increase both hp and tq throughout the powerband.
Think of your (or any) engine as nothing more than a big air pump.....let me explain.
You have your intake, which brings air into the engine to be mixed with fuel for combustion, the spent gasses are then expelled out the exhaust ports of the head. From this point, the smoothest and most direct route out the headers/exhaust/tailpipe will allow the engine to push more exhaust at a much faster rate than a restrictive, or unsmooth exhaust path.
Basically, the faster your engine can pull air into it, and push exhaust out of it, the more efficient and powerful it becomes.
-Ted
Old Aug 14, 2005 | 08:22 PM
PurduePhiGam's Avatar
Car Info: 2005 WRX
someone from cobb told me if i installed a header, i would get "hella turbo lag"
however, i thought that more flow = faster flow = faster spool. am i wrong?
this is assuming the header would be tuned (cobb stage II)
Old Aug 14, 2005 | 08:32 PM
Nick Koan's Avatar
Car Info: Legacy GT
Cobb may be still subscribing to the old notion that aftermarket headers aren't good for turbo Subarus. The reason early headers got turbo lag was because they were poorly designed for more flow, which actually slows the spool time because the velocity is reduced (if the same volume of air is being pushed). If you have a bigger volume of air to move, then it will move slower because there is more air to push.
Also, there is an issue of heat loss. If the air in the headers lose heat, they also lose velocity. Less velocity equals slower turbo spool up. So, you don't want a lot of flow, just the right amount. Thats why you need well engineered headers.
You'll need to be careful when selecting headers for the WRX or STi. Ask about things like horsepower gain and turbo spool up (unfortunately, I don't have enough experience to offer any advice on good brands to buy). Most do best with a tune as well.
SpeedDynamics
Mar 22, 2007 11:48 AM
mudpie
Sep 15, 2006 09:45 PM
gruppe-s
Engine and Drivetrain
Dec 17, 2005 10:27 AM
thebankman
May 13, 2004 12:29 PM
minisiu
Nov 4, 2003 08:16 PM
