problems with my AEM intake
Old Jan 30, 2003 | 08:56 PM
Zoeb2s's Avatar
I <3 White Girls
did you reset the ECU initially after installing the intake or did you do it after reading the responses?...I just want to know for my self If I need to reset the ECU after installing an intake cuz I will be doing that soon..
Old Jan 31, 2003 | 08:03 AM
bamfwrx's Avatar
Car Info: 02 WRX
did you notice any gains other than the increased noise? after you installed the intake
Old Jan 31, 2003 | 10:59 AM
mmboost's Avatar
read this thread:
https://www.i-club.com/forums/showth...&threadid=7657
Sell the intake and do something more worthwhile for your car. Those power increases are most likely psychosomatic
jason
Old Feb 3, 2003 | 10:10 AM
mmboost's Avatar
I doubt it. Did you read that threat I pasted above?
A BOV works when the throttle closes to relieve back pressure on the compressor. It keeps the compresser spinning between shifts and extends the life of your turbo. It has nothing to do with your mixture.
And my guess is you are misinterpreting the code. I don't think its lean because you have all that much air. I think its lean (or thinks its lean) because you are giving your ECU confusing readings because of the intake.
Take it out. If you really are running lean you could very well be hurting things, not to mention actually losing power because the ECU would correct.
jason
