Problems matching Perrin down pipe to Cobb cat back.
Old Jun 14, 2004 | 10:28 AM
Lowball's Avatar
Car Info: 02Wag on 17's
I had the same problem with my Stromung cat back and ended up selling that and getting a Perrin cat back...which is pretty loud.
As long as you don't have a leak you should be fine. You could also get an aftermarket gasket and install that. I tried both but it still didn't work for me. The connecton at the DP to the cat back didn't seal and then the angle of the Perrin DP made the Stromung hit my rear dif and hit a sheet metal part toward the rear of the car.
Stromung told me that their set up was only designed for the factory cat back or a stromung set up and that it didn't work with all aftermarket DP's. Where Perrin said that their DP works with all aftermarked DP and stock. Which in this case it did not.
You may be able to take your car to a muffler/exhaust shop and see if they can cut and reweld some thing to make it line up correctly. May only cost you a few dollars.
Old Jul 13, 2004 | 01:12 AM
raazin's Avatar
Car Info: 2002 wrx wagon black
i had the same problem but it was able to install everything good luck
Old Jul 13, 2004 | 09:32 AM
UK n00b's Avatar
Car Info: the blue bucket
The Cobb catback has a kink in it to except the stock doughnut gasket, the best solution for this would be to have a muffler shop cut out the flange and kink and weld in a small section with a straight 1/2" flange. That way you can use any 3" 2 bolt gasket and seal the exhaust up.
Mike
151sti
Jun 3, 2012 07:56 AM
RallySportDirect
Miscellaneous
Nov 12, 2008 08:46 AM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
