Ping! Help!
Old Apr 4, 2005 | 10:35 AM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
Ok... curious.. how did you get a new engine/ trans/ clutch/ flywheel AND a voided warranty?
Old Apr 4, 2005 | 11:02 AM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
prob. had the work done and drove over the 36.000 mile mark
Old Apr 4, 2005 | 12:49 PM
mmboost's Avatar
How about posting a log. Do you have any ideas what your AFRs are? If you have a fuel problem that'd be the first indicator (beyond fuel pressure,etc). Unless you have a log of a knock even there's really no way to tell. What are you using for engine management?
jason
Old Apr 4, 2005 | 02:45 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
does it only knock when it's on boost?
Old Apr 4, 2005 | 03:50 PM
HellaDumb's Avatar
How does the warranty come into play if you've been tinkering with it?
How did the original warranty get "voided?"
Originally Posted by WRXtasy2003
I have no engine management, just the stock ECU... But if the timing controll sensor is owned it wont matter what Engine management I get... I have the car running at 14PSI with fittings running through the turbo lines.. The stock Boost controller doesn't function properly... Today though I just remembered I purchased an extended warrenty. I just dropped my car off at the shop.. I am sick of dealing with it...
Old Apr 5, 2005 | 09:56 AM
mmboost's Avatar
You put in a larger turbo, a larger fuel rail and a larger fuel pump ... and you have stock injectors and a stock computer? And you've been putting it into boost? I KNOW what's causing your problems! You see you put in a larger turbo, a larger fuel rail and a larger fuel pump with stock injectors and a stock computer. That's what causing the problem. Its just a feeling, I know.
Either get rid of the turbo, or get bigger injectos and engine management that's meant to handle that much fuel and air.
You've basically done something stupid and now you're paying for it. Rectify the situation or hurt your car.
jason
Old Apr 5, 2005 | 05:26 PM
MO REX's Avatar
Car Info: 02 PSM WRX
^^^^What he said.
Old Apr 5, 2005 | 06:23 PM
mmboost's Avatar
Originally Posted by MO REX
^^^^What he said.
I'm rich, beeyotch!
cyyeo
Jul 20, 2003 08:02 AM
IS2Scooby
May 28, 2003 01:31 AM
