Perrin IC hoses are on (most of them)
Old Nov 22, 2003 | 10:53 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
Smile Perrin IC hoses are on (most of them)
Spent about an hour this morning installing new, black Perrin hoses...all except for the blow-off hose back to intake.....the spring clamp was installed by the factory with the tabs DOWN, under the hose.....too much monkeying around trying to get needlenose under there to undo stock clamp....so I left the stock hose. Aside from that the install was a piece of cake, and had no poor-fitting issues like I have read about. I sprayed a very small amount of silicone spray-lube on the I.D. of the hose taht clamps over the outlet of the compressor and it went right on.
Initial impressions after driving car (stock except for Prodrive exhaust and no intake resonator): only slightly noticeable difference, car feels a little more hard-edged first coming into boost...about 3200rpm or so.
But the work wasn't bad.....about the same wrestling as changing plugs.
Thanks to Andrew and Mike at GB Motorsports in Hayward for the hoses.
tofuman
Jan 10, 2012 10:06 PM
slugrx
Apr 19, 2010 12:53 PM
Yin
Feb 22, 2005 04:14 PM
Speed FX
Dec 7, 2002 03:07 PM
