Perrin or Helix?
Old Dec 18, 2003 | 10:14 AM
jhong567's Avatar
Perrin or Helix?
I want to pick up a downpipe for the holidays and i was wondering if i should get a perrin or helix downpipe. Currently i am running a perrin uppipe and i was wondering if it is worth the 100 dollar price difference to keep everything perrin. thanks
Old Dec 18, 2003 | 10:18 AM
international B's Avatar
Chewwwwy
i dont think its worth the 100 price difference. go with the helix, it looks nicer too.
Old Dec 18, 2003 | 10:53 AM
jhong567's Avatar
do you think i should have any trouble fitting the helix dp to the stock piping?
Old Dec 18, 2003 | 11:05 AM
ScoobyBoy's Avatar
you might. when my bud installed his helix dp to stock piping, he had a slight leak. but then again he didnt have a gasket.
Old Dec 18, 2003 | 12:12 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
helix is nice
Old Dec 18, 2003 | 12:24 PM
namitherussian's Avatar
Car Info: Black WRX
Helix
Old Dec 18, 2003 | 12:25 PM
AWD 20T's Avatar
Car Info: 2009 G Ride
Helix!
Old Dec 18, 2003 | 12:48 PM
platypus's Avatar
Car Info: dangerous with a wrench
Helix seems to be a popular choice.
However, if you want the loudest exhaust evar, get the perrin downpipe and mate that up with the perrin exhaust. OMFG!!!
Old Dec 18, 2003 | 01:44 PM
BoOm's Avatar
Helix is a bellmouth, compared to a Perrin which has a divorced wastegate.
Old Dec 18, 2003 | 01:56 PM
platypus's Avatar
the perrin (IIRC) is a divorced wastegate, but it rejoins the main flow at a severe angle about 3-4 inches downstream from the turbo. This wouldn't really gain much in terms of avoiding turbulence in the exhaust flow, I don't think (but I am not a professional fluid dynamacist). The Helix bellmouth style puts the wastegate flow into the same area as the main exhaust flow, but it's all travelling the same direction, so it might even result in lower turbulence in the exhaust stream.
If the flow is really the paramount thing for you, you'd do well to look at the Bosal downpipe. A divorced wastegate stream that rejoins the main flow far, far downstream and even has a nice angle of entry back into the main flow.
Old Dec 18, 2003 | 02:19 PM
AzN121184's Avatar
Car Info: civic
helix has a full 3 inch bellmouth i belive and i heard it's a really good dp, so go with the helix
Old Dec 18, 2003 | 10:11 PM
DarkAngel's Avatar
yea thats a huge difference. I like the look of the helix as well
Old Dec 18, 2003 | 10:34 PM
mmboost's Avatar
I had a solid perrin. Great pipe until I decided to install my EGT probe in the passenger size manifold. Little did I know at the time that when disconnecting from the uppipe on the bottom, you still need to disconnet at the top, and not just the uppipe but the turbo from the downpipe too. Then you retorque everything back down in a round-robin sort of fashion. I didn't do that work on the turbo side and within a couple of weeks after I installed my EGT probe I had a steadily growing leak at the top of my uppipe between itself and the turbine.
With the Helix flexpipe I have now, I should be able to take apart either side and not have to worry about the other side. Cuts the work down considerably. And even though the Perrin pipe is an excellent piece of hardware, with the flex pipe my chance of leaks over time just do to wear and tear are that much more greatly diminished.
jason
Old Dec 18, 2003 | 11:12 PM
islandx's Avatar
I like the Perrin pipe, I don't have it but like the divorced wastegate idea....my cusco pipe has a divorced gate and it seems to work great
