Painting the intake manifold?
Old Jan 6, 2006 | 12:06 PM
Dre2932's Avatar
Car Info: Women Crazy
Question Painting the intake manifold?
The Impreza is totally getting rebuilt for the last time and I want to paint up some engine parts. I was wondering can the intake manifold be painted and should anything be taped off?
Old Jan 12, 2006 | 02:42 AM
Wingless Wonder's Avatar
Yes, you can paint the intake manifold. Don't paint the throttle body, any rubber hoses or vacuum lines, or any electrical wiring or connectors. Don't let paint get into the area where the fuel injectors are installed. Paint contains solvents which might damage those components.
Obviously, better results will be had by removing the intake manifold from the engine before painting. Leaving it installed on the engine means a lot more work masking things off and trying to avoid overspray that might get on your fenders or other exterior surfaces. An air brush and compressor would probably do a nicer job of painting but I don't own one myself so no specific recommendations.
Old Jan 12, 2006 | 09:26 AM
Dre2932's Avatar
Thanks a lot. Yeah, my plan was to remove the manifold from engine.
Old Jan 12, 2006 | 02:19 PM
Another thing that can be done to prep the intake manifold is to thoroughly clean the surface of any grease, oil, or contaminants, so the paint can adhere properly. You might have some method in mind already but I might just use plain old mild detergent, hot water, and a scrub brush, then rinse well before allowing to dry (inside and out) completely.
If the painting job goes the way you like, feel free to post up pics.
Old Jan 12, 2006 | 04:59 PM
Donkey's Avatar
Car Info: 02' WRX
Send it out to get a thermal dispersent coating!http://www.techlinecoatings.com/intr...rmaldispersant
castro
Apr 14, 2008 09:52 PM
Renick Motorsports
Engine and Drivetrain
Sep 23, 2006 11:29 PM
Imprezer
Sep 7, 2004 07:36 AM
suafast
Feb 25, 2004 10:13 AM
